Gelsamel Epsilon
- 315
y = x+(m/(ax^n+b)+c?
I'm trying to find the equation for a graph in which the equation changes for different points.
The graph can be made accurate upto 1500, but after that it becomes inacurate for my numbers, using this equation;
[tex]x+(x*(.8-(\frac{3x}{5000})[/tex]
or
[tex]x*(1.80-(\frac{3x}{5000}))[/tex]
As you can see, it's sort of like modifying x by a percentage, that decreases as x gets bigger, an equation which changes as x does. At 0 the modifer is 180% or +80%, at 50 it's 177% (+77%), the modifer drops 3% each 50 along the x axis. At 500 its 150%, at 1000 its 120% all the way down to 0% at 3000, The problem with this is that when ever I put this into a calculator it doesn't go 3000+(0% of 3000) which WOULD = 3000, instead it somehow calculates 3000 x 0% = 0.
The idea is that as x increases y increases but at a slower rate, like an exponential function (if X > 0). Problem is I can't find any exponential function to fix it (My calculator is gay, and even though the numbers are fairly round I can't manually find one that fits it, every time I get close and add a +c to the equation it goes spastic), it was suggested to me that maybe it is a, [tex]x+(\frac{m}{ax^n+b})+c[/tex] type equation which would complicate things.
Maybe I am looking to hard, maybe I'm just an idiot but after a few hours of thinking about it my head is startinig to hurt and I'm getting lazy so any help will be usefull.
~Gelsamel
I might have to edit this if the tex is stuffed up, first time using it lol.
Edit: Okay I think I got the tex stuff down. Hehe.
or
~Gelsamel
