Finding a Basis and Dimension of Set W in R^4
The discussion revolves around identifying a basis and determining the dimension of the subspace W defined in R^4, specifically the set W={(a, 2a, b, 0)| a, b ∈ R}.
  • Participants explore the representation of the set W in terms of linear combinations of vectors. There is a discussion about the implications of linear independence and spanning sets in relation to the basis and dimension of W.
Some participants have provided insights into the structure of W and its basis, while others express uncertainty about the material and seek clarification. There appears to be a productive exchange of ideas regarding the concepts of basis and dimension, although not all participants are fully confident in their understanding.
One participant mentions the challenge of studying through correspondence without access to class notes, which may affect their grasp of the concepts discussed.
chantella28
The set W={(a, 2a, b, 0)| a, b eR} is a subspace of R^4. Find a basis for W and find dimW
(a,2a,b,0) = a(1,2,0,0) + b(0,0,1,0).
At this point if you can't see what a possible answer is then you should review your notes.
i've been reading through the text, but I'm doing the course through correspondence so I don't have class notes
i am guessing from that though that dimW would be 2?
Oh ok, I wasn't aware of that, sorry.
The set you have can be expressed as W = {a(1,2,0,0) + b(0,0,1,0) | a,b e R}. That's obtained just by factoring a and b, nothing special.
In this form, it is easy to see that W can be expressed as the span of the vectors (1,2,0,0) and (0,0,1,0). So any vector in W can be expressed as a linear combination of (1,2,0,0) and (0,0,1,0). So {(1,2,0,0),(0,0,1,0)} is a spanning set for W. Also, it is clear that the set is linearly independent. What can you say about a spanning set for W which is linearly independent?
Edit: You're correct about the dimension.
ah... it forms a basis... thanks for explaining this, i understand it now... wish my textbook would just explain it like that instead of getting into a whole bunch of mathematical proof stuff expecting us to figure out how to solve it from that
  • · Replies 58 ·
