Electron Config: Same for O, Ne, Mg (2+); Ni, Zn (2+); Hg, Tl+, Pb (2+)
The discussion centers on identifying sets of atoms or ions with the same electron configuration in their ground state. The correct answer is that sets I and III are isoelectronic, while set II is not. Specifically, O2-, Ne, and Mg2+ all share the electron configuration of [Ne], while Ni, Cu+, and Zn2+ do not share the same configuration due to the unique electron arrangements of Cu and Ni. Additionally, Hg, Tl+, and Pb2+ all have the configuration of [Xe].
  • Understanding of electron configurations and ground states
  • Familiarity with isoelectronic series
  • Knowledge of atomic structure and ionization
  • Basic principles of electron shell configuration
  • Study the concept of isoelectronic species in detail
  • Learn about electron configurations of transition metals
  • Research the implications of ionization on electron configurations
  • Explore the periodic trends in electron configurations
Chemistry students, educators, and professionals interested in atomic structure, electron configurations, and the behavior of ions in chemical reactions.
Soaring Crane
Which of the following three sets consist of atoms or ions with the same electron configuration in the ground state?
I. O (2-), Ne, and Mg (2+)
II. Ni, Cu+, Zn 2+
III. Hg, Tl+, and Pb (2+)
a. all but (II)
b. all but (I)
c. all three sets
d. only (I)
Is it all but ii. because Cu loses its 4s shell?
Thanks.
Aka isoelectronic series
Well O2-, Ne, and Mg2+ all have the configuration of [Ne]
and for 2 Ni is [Ar] 3d8 4s2
and Zn is [Ar] 3d10 4s2
Zn+2 would then be [Ar] 3d10 because you take from the outermost shell
Cu is [Ar] 3d10 4s1 so Cu+ would be [Ar] 3d10
So 2 isn't isoelectronic
For #3, Hg is [Xe] 4f14 5d10 6s2
Tl is [Xe] 4f14 5d10 6s2 6p1 so Tl+ is indeed [Xe] 4f14 5d10 6s2
Pb is [Xe] 4f14 5d10 6s2 6p2 so Pb+2 is indeed [Xe] 4f14 5d10 6s2
So you are indeed correct but your explanation doesn't quite make sense to me.
11K
34K
  • · Replies 19 ·
11K
