Why is dm negative in the rocket equation derivation?
The discussion revolves around the rocket equation and the interpretation of the differential mass change, specifically the sign of dm. Participants are exploring the implications of treating dm as a negative quantity in the context of mass loss during rocket propulsion.
  • Participants are questioning why dm is considered negative in the equation and how this affects the overall derivation. There are different interpretations of the momentum conservation setup, with some suggesting alternative formulations that lead to differing signs in the results.
The discussion is ongoing, with participants providing insights into their reasoning and interpretations. Some guidance has been offered regarding the setup of the equations and the implications of using absolute values for dm. There is no explicit consensus, but various perspectives are being explored.
Participants are considering the implications of their approaches on grading and the clarity of their reasoning in the context of homework expectations. The discussion also references external resources for further exploration of the topic.
brentd49
I'll write the equation first, and then state my problem with it.
mv=(m+dm)(v+dv)-dm(v-v')
The book says that in the term (m+dm), that dm is a negative quantity. If I believe this, then what about the -dm(v-v') term? Why is dm negative?
If I were to derive it I would have (m-dm) and +dm(v-v'), then I wouldn't have to say "dm" is a negative quantity. But if I use this method, then my result is different by a minus sign.
Will someone please explain this in a more intuitive sense. Thanks
dm is negative because mass is being lost by the rocket. Of course, you're free to set up the momentum conservation either way. It might be helpful if in setting up your equations if you used absolute value signs around dm and write the explicit sign in front of it. You'll just have to be careful when you finally attempt to integrate the differential equation.
Using the textbook method their result: mdv=-v'dm
My method I get: mdv=v'dm
And if I were to integrate to find the velocity as a function of mass, I would integrate from m(t) to m. This is exactly opposite the textbook method, so I end up with the same result.
So does the differential form really matter then, if I am off by a negative? i.e. Would a professor be just in docking off points?
A good prof wouldn't dock you if you make it clear what you are doing and it is valid.
  • · Replies 42 ·
