Energy Requirements for Compressing Matter into a Black Hole
The discussion centers on the energy requirements for compressing matter, specifically a coffee mug, into a black hole. Participants explore the theoretical implications of compressing various objects, including smaller sizes like atoms, and the necessary energy or force to achieve such compression. The conversation touches on concepts from physics such as degeneracy pressure and relativistic particles.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions how much energy is needed to compress a coffee mug into a black hole and whether less energy would be required for smaller objects.
  • Another participant provides a rough estimate, suggesting that compressing a coffee mug to the size of an electron would be necessary to form a black hole, humorously noting the impracticality of such compression.
  • A different participant proposes a method to think about the problem in terms of force required to overcome neutron degeneracy pressure, referencing the work done in compressing the object.
  • One participant expresses uncertainty about solving the problem of a relativistic particle in a box and discusses the complexities of computing energy for fermions in a confined space, mentioning the Schwarzschild radius and assumptions about adiabatic compression.
Participants express varying degrees of uncertainty and differing approaches to the problem, indicating that there is no consensus on the exact energy requirements or methods for compression into a black hole.
Participants note limitations in their approaches, such as the simplifications made in calculations and assumptions about the conditions of compression, including the adiabatic nature of the process.
-Job-
How much energy would it be necessary for me to compress my coffee mug into a black hole? Would i need less energy for an object with a fraction of the size of my coffee mug? How much energy would i need to collapse a single atom into a black hole, or is that not possible, and is a lot of matter a requirement?
Astronomy news on Phys.org
With no math ability, this is just a rough guess. A coffee cup would have to be compressed to somewhere around the size of an electron to become a black hole. I don't think that you could find a set of pliers small enough.
A simpler way to think about it would be to think in terms of the force required, which would be enough force to overcome neutron degeneracy pressure. To apply that force from all directions, through a distance that would essentially compress the mug to a point would require a certain amount of work, a la
[tex] W = \int \vec{F} \cdot d\vec{r}[/tex]
That is roughly the amount of energy needed(I say roughly because I somewhat simplified the problem).
I tried to take a stab at this, but I'm not sure how to solve the problem of a relativistic particle in a box.
For all of the different realms (white dwars star matter, neutron degenerate matter), the key problem in computing the energy is that of fermions in a box.
The box here is going to be very small, G/c^2 is 7.42471382 × 10-28 m / kg
and the Schwarzschild radius is r=2(G/c^2) M.
I suppose that this isn't quite right due to the non-euclidean geometry inside the "box", but it would be a first stab.
It wasn't specified, but I would assume that we'd assume that the compression was adiabatic.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 22 ·
