Force and Motion (with tension)
The discussion revolves around a physics problem involving a skier being pulled up a frictionless slope by a towrope. The skier's mass is given, along with the slope's angle and two scenarios regarding the skier's velocity—constant and accelerating. Participants are examining the forces acting on the skier, particularly tension and gravitational components.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the free body diagram (FBD) drawn by the original poster, questioning the orientation of the tension force and its relationship to the skier's weight. There are inquiries about how to proceed with the problem and the relevance of different force components.
Some participants have provided guidance on considering the forces parallel to the slope and applying Newton's second law. There is an acknowledgment of the importance of the weight component along the slope, while the role of the y-component is debated. Multiple interpretations of the force directions are being explored.
Participants note that the problem is set in a frictionless context, which influences the relevance of certain forces. The original poster's understanding of the axes in relation to the slope is also under discussion.
th77
Holding on to a towrope moving parallel to a frictionless ski slope, a 50 kg skier is puilled up the slope, which is at an angle of 8 degrees with the horizontal. What is the magnitude Frope of the force on the skier from the rope when (a) the magnitude v of the skier's velocity is constant at 2.0 m/s and (b) v = 2.0 m/s as v increases at a rate of 0.10 m/s^2?
I drew the free body diagram. I have the normal force Fn along the y-axis. I have a force T (tension) along the x-axis. Then I have Fg making an angle that is 8 degrees to the negative y-axis.
My first question: Did I draw the FBD correctly?
Next question: How do I proceed from here?
This may not be of much use as I have not done too much work yet with mechanics but shouldn't the tension force be parallel to the ski slope and acting upwards? as opposed to aligned with the x-axis, the persons weight has two components, and in the original question -part (a)- as velocity is constant and friction is ignored, one of the vectors that that represents the person's tendency to move down the slope should be equal and opposite to the tension in the string.
(the normal force should be of help for finding the frictional force but here it is nil)
I'm not sure. Thats part of my question.
The person being pulled up the ski slope resides on the same plane as the object that is towing him (or her). Imagine where the rope would be if connected to these two bodies, what is causing tension in the rope? and which of these is relevant to your question?
Assuming your x and y axes are defined as parallel and perpendicular to the slope, it looks like you are on the right track. Next consider the forces parallel to the slope (along the x direction), as that's the only direction that the skier can move. (What's the component of the weight along the x-direction?) Apply Newton's 2nd law to both cases to solve for the tension force.
The weight along the x-direction is mgsin 8 . Does it matter what the y component of weight is?
Using Newtons 2nd law would it be T - mg sin 8 = ma ?
Right.
Not to me. :wink: (All we care about are forces in the x-direction. If there was friction, then the normal force would matter.)
Exactly.
Thanks very much!
  • · Replies 18 ·
