How Does Work Done Compare in Isothermal and Adiabatic Expansion of Gases?
  • Thread starter Thread starter dimensionless
    Expanding Work
The discussion revolves around comparing the work done during isothermal and adiabatic expansions of an ideal monatomic gas. Participants are exploring the mathematical expressions for work done in both processes and the implications of the relationship between these values.
  • Participants are attempting to derive the work done in both isothermal and adiabatic processes, questioning the antiderivative of the function involved in the adiabatic case. There are inquiries about the maximum value of the heat capacity ratio, γ, and its implications for the problem.
The discussion is active, with participants sharing their calculations and questioning the relationships between variables. Some participants have provided guidance on drawing pressure-volume diagrams to visualize the differences in work done between the two processes, while others are still clarifying definitions and mathematical expressions.
There is mention of specific values for heat capacities and the minimum value of Cv, which may influence the understanding of γ. The original poster and others express confusion regarding the inequalities related to work done, indicating a need for further exploration of the concepts involved.
dimensionless
I've been trying to tackle the following problem, but I can't seem to get it right.
An ideal monatomic gas expands quasi-statically to twice its volume. If the process is isothermal, the work done by the gas is W_i. If the process is adiabatic, the work doen by the gas is W_a. Show that 0 < W_a < W_i.
For isothermal processes I have
[tex] W_i = \int_{v_i}^{v_f} \frac{nRT}{V}dV = nRT ln(2)[/tex]
For adiabatic processes I have
[tex] W_a = k \int_{v_i}^{v_f} \frac{dV}{V^{\gamma}}[/tex]
Where do go from this point?
[tex]W_i = \int_{v_i}^{v_f} \frac{nRT}{V}dV = nRT ln(2)[/tex]
What is the antiderivative of:
[tex]\frac{1}{V^{\gamma}} = V^{-\gamma}[/tex]?
Also: [itex]k = P_iV_i^\gamma[/itex]
What is the maximum value of [itex]\gamma[/itex] ?
AM
I've got [tex]\gamma = C_p/C_v[/tex] written down as the only definition for [tex]\gamma[/tex].
I don't know of any alternative for [tex]V^{-\gamma}[/tex].
But what is the maximum value it can have? What is the minimum value of [itex]C_v[/itex]? What is [itex]C_p - C_v[/itex]?
That's ANTI-DERIVATIVE. What is the function F(x) such that [itex]F'(x) = x^n[/itex]?
AM
I've got [tex]C_p - C_v = \frac{5}{2}R-\frac{3}{2}R=R[/tex]
and [tex]V^{-\gamma} = -\gamma V^{-\gamma-1} dV[/tex]
I've worked this out but I get [tex]0 < W_i < W_a[/tex] instead of [tex]0 < W_a < W_i[/tex] for an answer.
?? How do you figure that?
The antiderivative of [itex]V^{-\gamma}[/itex] is: [itex]\frac{1}{-\gamma +1}V^{-\gamma + 1}[/itex]
[tex]\int_{V_i}^{V_f}\frac{dV}{V^\gamma} = K\left(\frac{V_f^{-\gamma + 1} - V_i^{-\gamma + 1}}{-\gamma + 1}\right)[/tex]
Use the fact that the minimum value of C_v = 3R/2 and [itex]-\gamma + 1 = 1 - \gamma = -(C_p - C_v)/C_v[/itex] to work out the inequality.
AM
Do this:
For the first process , the isothermal one , we know for an ideal gas :
[itex]PV = K[/itex]
Draw the Pressure versus Volume diagram for the first process (isothermal) , with values as per given in the question.
For the second process , draw the Pressure versus Volume diagram , you know that for an adibatic change:
[itex]PV^(\gamma) = K[/itex]
Take P_1 and P_2 for both the processes to be the same.
Because you know area under PV graph gives the work done. You would find that because of the factor "gamma" for adiabatic process , it will have a steeper slope in the graph and thus lesser area as compared to that of isothermal process.
BJ
