Is Your Classroom an Inertial Frame of Reference?
  • Context: Undergrad
  • Thread starter Thread starter madking153
    Frames Inertial
The discussion centers on whether a classroom or laboratory can be considered an inertial frame of reference, particularly in the context of Newton's laws of motion. Participants explore the implications of Earth's rotation and gravity on the classification of frames as inertial or non-inertial, and how to determine the inertial status of a given frame based on relative motion.
  • Some participants suggest that a classroom is not an inertial frame due to Earth's rotation, while others argue that under certain conditions, such as short time scales, it can be approximated as inertial.
  • One participant notes that gravity makes any frame on Earth non-inertial, but asserts that Newton's laws can still apply in those frames.
  • Another participant explains that an inertial frame can be determined by comparing it to another frame of reference, using examples of relative motion between cars and the Earth.
  • A participant questions the definition of an inertial frame, suggesting it should be defined by the absence of acceleration rather than being stationary.
  • Some participants clarify that inertial frames can exist for bodies moving at constant velocity, while others emphasize the need for a simplified understanding for beginners.
  • There is mention of the Foucault pendulum as evidence that the Earth is not an inertial reference frame, which leads to further discussion about the validity of Newton's laws in various contexts.
  • One participant argues that the inertial frame is not arbitrarily determined but can be defined operationally using instruments like accelerometers.
Participants express multiple competing views regarding the definition and determination of inertial frames. There is no consensus on whether a classroom or laboratory can be definitively classified as an inertial frame, and the discussion remains unresolved with differing interpretations of the concepts involved.
Limitations include varying definitions of inertial frames, dependence on specific conditions of motion, and the complexity of applying Newton's laws in non-inertial frames. Some participants highlight the need for further clarification on the relationship between acceleration and inertial frames.
madking153
Are you in inertial frames?
hi, today my friend ask me 2 simple questions, too shame i cannot answer him...so i post it here:
is the classroom an inertial system ?? Earth is rotating around the sun - so ...can still consider as inertial ?
2. If u working in laboratory to find so physics equation.. How you decide whether ur lab is an inertial system ( Coz if Lab is not an inertial system - then Newton's Law cannot apply)
Your classroom is not an inertial frame for the reasons you cite. Depending on the conditions of the physical experiment, you may or may not approximate your lab as being an inertial frame of reference. For example, if you are doing a Foucault pendulum experiment you must take into account the fact that you're not in an inertial frame. However, if you are doing ballistic pendulum experiment where the time scales are short compared with the rotational period of the Earth then you can safely ignore noninertial effects due to the rotation.
The presence of gravity makes any frame on the Earth non-inertial. However, Newton's laws still hold.
but his question is : How to determine that your lab is in inertial frame or not ?
An inertial frame can be determined only by comparing it to a frame of reference. For example, I am in an inertial frame with respect to the Earth but NOT with respect to the sun. The reason is that I am traveling at the same velocity as the Earth so if I stand on a point and look at a point on the Earth (such as my computer) it appears to be "inert" (not moving). If I look at the sun in the sky (not recommended), it would appear to be moving while I stand still because our relative velocities are not the same. An easier example would be if two cars travel at the same speed. Passengers in one car would view the people in the other car as sitting there and not moving (even though both cars ARE moving). If a person sitting on the side of the road watched the people in a car move by they might say they are moving at 40m/s (relative to the person on the side of the road), but to the people in the car next to them it would appear that the people are moving at 0 m/s (relative to them, they are traveling at the exact same speed so it appears that they are not moving).
Basically, NOTHING in the universe is inert (everything is moving relative to something else). The "inertial frame" is an arbitrarily determined frame of reference with which we consider our movement to be zero while we measure the movement of something else (what we are actually measuring is therefore the *difference* between two velocities, and we just decide to start measuring by setting our velocity to "zero" as a reference point to start the measurement). This is all stuff credited to Einstein's general/special relativity if you want to read up on it.
To answer the question, if you consider your current velocity to be zero and you look at the lab and the lab is not moving then the lab is in an inertial frame of reference. If you start running and look at the lab, the lab will appear to be "moving" at some velocity. So if you set YOUR velocity to zero as the inertial reference while running, then the lab is not inert (you can't set it's velocity at zero when you start measuring), because it is moving with some velocity relative to yourself.
Thanks for the reply -- i am clear now
thanks
I thought an intertial frame was one that was not accelerated, not necessarily one which was stationary.
that is, the fact that your two cars, and the person on the side of the road are not accelerating, instead maintaining a constant state of motion means that they in fact ARE inertial frames
feel free to shoot me down if i wrong though...am only coming to the end of my first year of university physics, so it is highly possible i have not understood something...
That is true. I gave a "simplified" explanation to make the idea easier to understand. The inertial frame can exist for bodies "at rest" or moving "uniformly at constant velocity" (but not for other velocities that are not moving uniformly), but I have found it is much easier to explain it to someone with the condition that the bodies be at rest relative to one another for inertial frames (and that non-inertial frames be moving). That way they can see the distinction clearly and can add in the detail that constant velocity frames can be considered inertial at a later point (after they have grasped the basic concept).
If I wanted to be a stickler, I can add more detail to the car example by saying that both cars were accelerating at the same rate relative to each other (that is, their velocity is changing every second), and that the person on the side of the road measured an instantaneous velocity of 40 m/s and that the two cars are in inertial frames with each other, whereas the guy on the side of the road is not in an inertial frame with respect to either car, but this attempt at being "more correct" tends to confuse things, no?
i spose that would make it confusing...
An inertial reference frame in classical physics is one in Newton's Laws are valid. The Foucault Pendulum shows that F=ma is not true on the surface of the Earth -- i.e., the Earth is not an inertial reference frame. No comparison to other frames need be made.
An "inertial frame" is not determined arbitrarily. It can be operationally defined by the state of an accelerometer (and Foucault pendulum) carried by the frame, without reference to any external reference frame. This determination is not "relative"... it is "absolute".
Consider two identically-moving cars traveling alongside each other. Suppose they decide to throw a ball from one car to the other. If they are traveling inertially, then the drivers will do exactly the same thing they would if they were at rest. However, if they are "accelerating at the same rate relative to each other", then one will have to throw the ball differently (because the ball will travel inertially). This unambiguously distinguishes the inertial case from the non-inertial one...without regard to a third reference frame.
There are two ways to answer this. Newton would answer it one way and Einstein another way. Newton would say that you're in an inertial frame, but that there are gravitational forces present. Einstein would say that its impossible to determine if you're at rest (i.e. sitting in a chair on the Earth's surface) in a uniform gravitational field or at rest (sitting in the chair of a rocket) in a uniformly accelerating frame of reference.
Pete
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 83 ·
