How Much Work Is Required to Push a Mass Up an Inclined Plane with Friction?
To calculate the work required to push a 100 kg mass up an inclined plane at a 20-degree angle with a coefficient of friction of 0.20 over a distance of 2.0 m, one must first determine the forces acting on the mass. The gravitational force component acting parallel to the incline is calculated using the formula F = mg sin(θ), where m is the mass, g is the acceleration due to gravity (9.81 m/s²), and θ is the angle of inclination. The frictional force is given by F_friction = μN, where μ is the coefficient of friction and N is the normal force. The total work done is the sum of the work against gravity and friction over the displacement.
  • Understanding of Newton's laws of motion
  • Basic knowledge of trigonometry
  • Familiarity with the concepts of work and energy
  • Knowledge of friction and its coefficients
  • Study the derivation of the work-energy principle
  • Learn about calculating normal force on inclined planes
  • Explore the effects of varying coefficients of friction on work calculations
  • Investigate real-world applications of inclined planes in physics
Physics students, engineers, and anyone interested in mechanics and the application of forces on inclined planes.
mahi
If a mass of 100kg is to be pushed up a plane inclined at 20 degrees from the horizontal, with a total displacement of 2.0 m, and a coefficient of friction of 0.20, how much work has to be done? Looking for the formula. Thanks!
Work is defined as force (parallel) component multiplied by the distance.Remember to label all the forces acting on this object of mass 100g.
  • · Replies 33 ·
