How to Identify an Airfoil from a Piece-wise Function?
  • Thread starter Thread starter physicsCU
    Airfoil
The discussion focuses on identifying airfoils represented by piece-wise functions, particularly using the NACA 4-digit convention. Participants clarify that for a NACA 2412 airfoil, the maximum camber is located at 24% of the chord length, while a NACA 0016 airfoil is symmetric with a maximum thickness of 16% of the chord. The conversation emphasizes the importance of understanding these conventions to match airfoils to their respective functions accurately.
  • Understanding of piece-wise functions in calculus
  • Familiarity with NACA airfoil naming conventions
  • Basic knowledge of aerodynamics principles
  • Ability to analyze airfoil characteristics such as camber and thickness
  • Research the NACA 4-digit airfoil classification system
  • Learn about the mathematical representation of airfoils using piece-wise functions
  • Explore other airfoil naming conventions beyond NACA
  • Study the impact of camber and thickness on airfoil performance
Aerodynamics students, engineers working with airfoil design, and anyone involved in computational fluid dynamics or aerodynamic analysis will benefit from this discussion.
physicsCU
OK, I have two labs, one in Calc 3, one in aerodynamics.
In calc 3, we are using an airfoil described by a piece-wise function. How can I figure out what the name of that airfoil is?
By that, I mean can I match up the airfoil to the function given?
Or will I have to work backwards and choose a known airfoil?
if you are using the standard NACA 4 digit convention then it works as follows.
For a NACA 2412, the maximum camber occurs at 24% down the chord from the leading edge, and the maximum thickness of the airfoil is 12% of the total chord length.
For a NACA 0016. the airfoil has no camber (thus is symmetric) and has a maximum thickness of 16% of the total chord lenght.
There are other naming conventions as well and the values are typically expressed in terms of % chord
  • · Replies 30 ·
