Is M-Theory Holding Up or Going Down the Drain?
  • Thread starter Thread starter Gold Barz
    M-theory
The discussion centers around the status and validity of M-Theory and string theory, exploring whether it is a robust theoretical framework or if it is failing to provide predictive power. Participants engage in a range of topics including the nature of predictions in string theory, the implications of extra dimensions, and the mathematical foundations of these theories.
  • Some participants argue that string theory lacks clear, testable predictions, which raises questions about its scientific validity.
  • Others suggest that string theory does predict fundamental building blocks, but these predictions are not easily testable due to limitations in our dimensional perception.
  • A participant points out that the search for extra dimensions could involve examining gravitational forces at different scales.
  • Concerns are raised about the reliance on mathematical consistency without empirical predictions, questioning the distinction between mathematics and physics.
  • Some participants assert that the foundational postulate of string theory—that strings are fundamental—has been challenged by brane theory, which posits that strings are approximations of more fundamental point-like objects.
  • There is discussion about the role of parameters in string theory, with one participant noting that string theory has many more free parameters compared to the Standard Model, complicating its predictive power.
  • A viewpoint is presented that suggests string theory and loop quantum gravity (LQG) may represent different approaches to understanding the universe, with each focusing on different aspects of physical reality.
Participants express a range of opinions, with no clear consensus on the validity or future of M-Theory and string theory. Some believe it is fundamentally flawed, while others defend its mathematical elegance and potential.
Limitations in the discussion include unresolved questions about the nature of predictions in string theory, the implications of extra dimensions, and the relationship between mathematical formulations and physical reality.
Gold Barz
Is it a pretty good theory that's holding up or is it about to go down the drain?
I should point out first that there is still no theory with that name. People believe (some strongly, some not) that many string theories will eventually merge into that "M", but that is not so yet.
Regardless of that, talking about string theories, you will listen very varied opinions on this matter (holding up versus going down the drain).
they say string theory makes no predictions...
...but doesn't it predict a fundamental building block of a 1d point/loop, the vibrational signature and dimensionality of which determines the nature of particles, elements, light, mass and gravity ?
only trouble is it can't be tested because we are eternally locked into 5 sense in 4 dimensions...
They mean checkable predictions. Things that could be measured at Tevatron or the next collider, LHC.
so how does one test for extra dimensions or symmetric particles operating in quantum fields ?
Isn't strings extra dimensionality the equivalent of unseen fields operating wavelike within 4d spacetime which particles couple to and gain mass/gravity ?
is the search then is for the mechanism or is that what the LHC is supposed to replicate ?
One way to search for extra dimensions (if they're very small) is to check if the force of gravity per distance is different on very small scales than what it is on very large scales. Some people think that the reason that gravity is so weak over large macroscopic (and sofar microscopic) distances is that some of it goes to the other dimensions while what's left is very weak.
It does not predict[/color] the 1d loop; it starts from there.
But it does not make a clear, unique prediction of the output of an experiment.
you mean like some models don't predict a singularity, it just starts from there...
...isn't the proof for string in the maths and that is fundamentally sound, i mean isn't eveything maths based and as long as that stacks up then it's sweet ?
I don't get why it has to make a clear and unique prediction of the output of an experiment ?
...and just cos it doesn't people want to bin it in favour of what ?
surely there has to be some sort of fundamental minimum scale particle that operates string like in 4d ?
so perhaps a rose by another name...
The one great thing that String physics has going for it is the sweet math. It is impressive, but then the mathematicians have gobs of sweet math, and that isn't physics. The point is that if the only things you can say about the universe are things that can't possibly be checked, then what good is your theory? Is it only an art form, to be admired without doing anything?
Last advances prove that string theory is unable to predict anything. Therefore has failed like a theory of physics.
The problem of string thorists is that was not sincere in the past. They claimed that are computing this and this other when was not true. For example in comutation of black hole entropy they begin from a well defined geometry then split it by hand and choose by hand the correct 4D manifold compatible with GR (that is not a prediction) then write the equations for the action and next modify they again by hand by compatibility by thoughts from GR.
Next they write a model of Black hole what is NOT the model of GR (it is a theoretical model invented by string theorists) and compute the entropy. They obtain a correct result, but the way was forced. It was not a derivation.
They wait that in a future they could do a ab initio computation from first principles of string theory. BUt those principles nwer were found and recent advances proven that due to vacua degeneraty, string theory CANNOT predict anything. One may complement the theory with experimental data because there is a minimum of 10000 parameters that are not fixed by theory and that in prinple cannot even be experimentally measured.
The Standard Model of particle physics contained less than 20 parameters that are obtained from experiment. Once you know the parameters (somewhat as you know what is the value of constants as c, G, etc.) you can predict things
Effectively, string theory does not predict building block of a 1d point/loop, string theory begin from that postulate.
But that postulate is WRONG. As proved in brane theory (yes people does not know it), the strings are NOT fundamental (string theorists were wrong) and the simplicity of 1d loops is missed.
Brane theory is based in p-branes, where p is an index goes from 0 to 9. The string is not fundamental except as approximation.
Still more interesting is the ONLY formulation of M-theory known. I refer to Banks M(atrix) theory.
In M(atrix) theory, the fundamental object are pointlike objects in 10D, doing the traditional idea of that pointlike objects are approximations just outdated.
It is more M(atrix) theorists have proven that the string (an 1-brane) arise like an approximation from a pointlike object.
Remember that during decades string theorists claimed that the string was fundamental and that pointlike objects of Standard Model of particle physics an approximation.
M(atrix) theory is not complete.
because that is the only way other than direct observation that string, or any other theory for that matter, is able to make the leap from philosophy to physics or more to your point from math to science.
Juan R. said:
Effectively, string theory does not predict building block of a 1d point/loop, string theory begin from that postulate. But that postulate is WRONG. As proved in brane theory (yes people does not know it), the strings are NOT fundamental (string theorists were wrong) and the simplicity of 1d loops is missed.
An alternative view is that stringiness emerges via a system of constraint. So the fact that it is "approximations" all the way down the hierarchy is simply a reflection of the fact that physical reality is constructed by an asymptotic approach to limits.
String theories model the harmonics of symmetries. LQG theories are focusing on the self-organisation of the spaces that can sustain the harmonies. One models figure, the other ground, perhaps. But I agree that fundamental mistakes are being made because people don't see that the universe is a system and systems have their own science as well.
Cheers - John McCrone.
...then what is ?
Is not the initial postulate proven by the sweet maths which then predicts a string like object ?
Is there no fundamental minimum scale building block or if there is what would YOU call it, how would you have it work and what would you have it do ?
me, i like bubbles, where a 3dsphere is the membrane made of light flickering on and off causing time and motion...
...but then again I'm just a simple know nothing dumbugga
:rolleyes:
dubmugga said:
...then what is ?
:rolleyes:
String theory is outdated. Today it was substituted by brane theory. In brane theory the fundamental object is the so called p-brane. with p = 0, 1, 2, 3, 4, 5, 6, 7, 8, and 9.
Some authors (e.g.Banks and his M-theory) claim that the fundamental object is really a D0-brane.
It is all pure confusion. String theory is a waste of time.
so what's your alternative Juan R. ?
I don't think it's enough to say something is a waste of time if you don't offer up something else to occupy one's time productively
For understand elementary particles?
An approach based in a non-perturbative quantum gravity study of topological regions in a 4D universe. Particles are studied in a similar way to the theory of pre-spinors in the sense of D. Finkelstein, the link with Coxeter groups...
For understand interactions?
A generalization of Fokker/Dirac/Wheeler/Feynman/Hoyle/Narlikar theory.
And yes, one can call string theory a waste of time because that is it really is. In fact, it is just that as have called by many many people. For example, Nobel Prize for Physics P. W. Anderson called string theory
a futile exercise as physics
at beginning of this year in a popular magazine.
I wish I'd never asked now...
:confused: :biggrin: :wink:
So it IS about to go down the drain, if it isn't already?
If you noticed the line through Juan R.'s name, that means he just got banned. Let that be a suggestion not to take his rant too seriously. String theory is in a quandary to be sure, with the landscape, but it is very far from "down the drain".
My mother used to say, "Never show anything half finished to fools and children!"
  • · Replies 26 ·
  • · Replies 21 ·
