| Thread Closed |
divergent series |
Share Thread | Thread Tools |
| Nov10-05, 11:01 AM | #1 |
divergent series
Hello, I'm working on this problem:
Prove that for any real x, the series SUM n=2 to infinity of 1/(log n)^x diverges. So far, I have applied the test that says that if SUM 2^n*a_2n converges then the series converges. I got: 1/log2*SUM 2^n/n^x I know that 1/n^x converges if x>1, but 2^n will explode, so I'd have convergent (sometimes) times divergent = divergent. Can I do that? Thanks, CC |
| Nov10-05, 01:22 PM | #2 |
No, that is not a propery of series. A counter exemple is
[tex]\sum \frac{1}{n}\frac{1}{n^2}[/tex] In this case, we have divergent times convergeant = convergeant. What you can do to prove the desired result however, is simply show that for all x in R, the limit as n-->infty of the argument of the serie is not 0. Hence it does not converges, hence it diverges. (You'll have to do the 3 separate cases x<0, x=0 and x>0 [the later being the most difficult]). |
| Nov10-05, 03:52 PM | #3 |
I tried it using the ratio test. I got
[tex]\2(\frac{n}{n+1})^x[\tex] and the limit of that is 2>1 so it diverges. can I do it that way? CC |
| Nov10-05, 04:05 PM | #4 |
divergent series
let me try again...I'm still learning latex....
[tex]\mbox{2}(\frac{n}{n+1})^x[/tex] there. And the limit of THAT is 2. Is this correct? |
| Nov10-05, 04:29 PM | #5 |
Recognitions:
[tex]\lim_{n \rightarrow \infty} 2 \left( \frac{n}{n+1}\right)^x=2[/itex] But [tex] \frac{(\log n)^x}{(\log n+1)^x} \neq 2 \left( \frac{n}{n+1}\right)^x [/tex] |
| Nov10-05, 07:01 PM | #6 |
You should do it my way. It's much more instructive then mechanically using a test anyway.
| Thread Closed |
| Thread Tools | |
Similar Threads for: divergent series
| Divergent Harmonic Series, Convergent P-Series (Cauchy sequences) | Calculus & Beyond Homework | 1 | ||
| series- convergent or divergent? | Calculus & Beyond Homework | 15 | ||
| is the series covergent or divergent??? | General Math | 6 | ||
| divergent series | Calculus & Beyond Homework | 4 | ||
| Inconsistent systems and divergent series (Re QFT, divergent series, | General Physics | 0 | ||
