Mass and time question using calculus
The discussion revolves around a physics problem involving gravitational forces and motion, specifically calculating the time it takes for two objects (an 8 kg turkey and an 8 kg ham) to touch each other on a frictionless table. The problem requires the use of calculus to integrate the gravitational force acting between the two masses.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to integrate the gravitational force to find the time until the two objects touch. There are attempts to clarify the relationship between force, acceleration, and distance, with some questioning the necessity of integrating the gravitational force directly.
Participants are exploring various methods to approach the problem, including the use of quadrature to relate velocity and distance. Some guidance has been provided regarding the integration process and the need to consider the changing acceleration as the objects move closer together. There is an acknowledgment of the complexity involved in finding a solution.
There is a mention of using average force in previous calculations, which may not accurately reflect the dynamics of the situation as the gravitational force changes with distance. Participants are also considering the implications of both masses moving towards each other.
harpgirl
I am working on an AP physics question that I am supposed to solve by using an integrated force(not an average) and I am a bit stumped. Please help!
An 8 kg turkey is placed 1 m(from their centers of mass) from an 8 kg ham on a friction less table. How much time passes before the turkey and ham touch?
(A picture that is above the question shows both the turkey and ham to be .2m wide, so it is only a distance of .8 m before their edges touch)
I have started by finding the integral of F=GMm/r^2 dr (from 0 to .4) by plugging in the gravitational constant and both 8 kg masses for M and m. I found the indefinite integral to be (4.27*10^-9)/r and the definite integral to be -1.07*10^-8 N Is this the work that I've found, and if so(or if not) where do I go next?
Okay I am rethinking this. What can I find the integral of to give me a force?
Integrating a force with respect to a distance gives energy.
Okay thanks for that information. So I don't need to integrate the gravitiational force, but what can I integrate to get the gravitiational force? What is measured in Newtons per time? Please tell me if I'm going in the wrong direction here.
Well, I'm not sure that differentiating force with respect to time will be helpful here.
I've thought a bit about this. You can find the acceleration of each particle as a function of their distance apart, although you need them as functions of time so you can integrate twice to get their positions as functions of time.
I'm unsure how to do this.
I have figured this question out without using calculus but it is only with an average force. Maybe if I explain what I did, you'll see something that I haven't and be able to help me find the true force.
I found the gravitational force to be 4.27*10^-11 by doing F=GMm/r^2
G=6.67*10^-11
M=8
m=8
r=1
Then I set that equal to F=ma where m=8 and I solved for a
a=5.34*10^-12 m/s^2
Then using d=vt+.5at^2 (where v is the initial velocity which is 0)
d=.4 (the distance one of the particles must move before touching the other)
a= answer from above
so t= 387,000 sec (approxiamately)
Did you think of a was to integrate to find this force?
Thank you for trying this!
Your answer is incorrect because you didn't integrate!
You calculated the intial force, used that to find the initial acceleration and then assumed that acceleration until they hit: the force of gravity between the two objects becomes greater as they get closer so the acceleration will increase.
You know F= ma so m dv/dt= -GmM/r2. But you need "dv/dr" not dv/dt since you have accelration as a function of r, not time. Use the chain rule: dv/dt= dv/dr dr/dt= v dv/dr:
m vdv/dr= -GmM/r2 so you can integrate v dv= -GM/r2 (this is a general method called "quadrature".)
After you know v as a function of r, v= dr/dt so dt= (1/v)dr.
You will need to take into account that both objects are moving.
I can follow and understand everything up to the quadrature part, how does that work?
I think what Halls was saying was that the two masses 'M' and 'm' are moving towards each other. The quadrature method will solve for the position of only one mass. And you wanted to work out the time for the masses to come together so you've got set each of their positions (with respect to time) equal to each other and solve for time. Just be wary of one thing, the mass on the RHS is traveling with a negative velocity from the equations that have been setup, but the algebra should sort that out:smile: !
  • · Replies 19 ·
