Conservation of Mechanical Energy
The discussion revolves around a physics problem related to the conservation of mechanical energy, specifically focusing on a car navigating a loop. The original poster attempts to determine the maximum radius of the loop that allows the car to maintain contact with the track throughout the motion.
  • Participants explore the relationship between kinetic and potential energy as the car moves through the loop. Questions arise regarding the necessary conditions for the car to remain in contact with the track, particularly at the top of the loop. There is also a discussion about the minimum velocity required at the top of the loop.
The discussion is ongoing, with participants providing insights into the conditions necessary for maintaining contact with the loop. Some participants suggest that the original poster's approach may not fully address the problem's requirements, indicating a productive exploration of the topic.
There is a focus on the implications of kinetic energy and gravitational forces, with participants questioning the assumptions made in the original calculations. The need for clarity on the minimum velocity at the top of the loop is emphasized, along with the understanding of forces acting on the car.
ChaoticLlama
A small car has an initial speed of 4.0m/s just before it enters a loop. What is the largest value for r (radius) that the loop can have if the car is to remain in contact with the circular track at all times?
Answer: r = 0.327m
What I tried was; before the car enters the loop it posses pure kinetic energy, and at the top of loop it posses pure potential energy.
Therefore..
1/2(m)(v)² = (m)(g)(Δh)
(1/2(v)²) / g = (Δh)
Δh = 0.816m
Since 2r = Δh
Therefore
r = 0.408m
What have I done wrong?
Would the car, at the top , stay in contact with the track without any kinetic energy?
How much velocity would the car need at the top of the loop to stay in contact with the rails? The question asked you what the largest value of r is so that the car remains in contact with the loop at all times. Try to figure out what conditions would be necessary for the car to stay in contact with the rails. You conpletely ignored this is your attempt. The answer you got is actually the answer to "what is the radius of the loop if the car just reaches the top an falls down?".
I still do not understand what to do.
Do I need to find the minimum velocity that the car has at the top of the loop? Or is finding the velocity unnecessary, and the radius can be found without it?
you have to keep the car TOUCHING the track at the top ...
this means find the speed needed at the top (as function of "r").
Then use KE => KE + PE to retain that much KE at the top.
Yea. To keep it just touching, the normal at the top is just about zero.
Think of gravity. Its pulling the car down. Due to the cars inertia, it exerts a force on the rails. The net force that the rails feel from the car should be >= 0 at the top. But since you want the minimum, you can take it equal to zero. have you learned about circular motion? think of the centrifugal force.
Actually, in his answer, the car falls down before reaching the top.
13K
  • · Replies 17 ·
