Is it possible to show that so(4) is equal to su(2) direct sum su(2)?
The discussion revolves around the relationship between the Lie algebras so(4) and su(2) in the context of Lie algebra theory. Participants explore whether so(4) can be expressed as the direct sum of two copies of su(2), examining both complex and real cases, and discussing the implications of different bases and isomorphisms.
  • One participant expresses confusion about the direct sum notation, suggesting that the matrices in so(4) do not conform to the expected form of a direct sum.
  • Another participant proposes an isomorphism that maps elements of su(2) into a subset of so(4), but notes that this does not encompass all of so(4).
  • A participant clarifies that the relationship so(4) ≅ su(2) ⊕ su(2) holds in the complex case, but questions its validity in the real case.
  • There is a suggestion that considering different bases might resolve some of the confusion regarding the structure of so(4).
  • One participant constructs a basis for so(4) and computes Lie brackets, concluding that the structure aligns with two copies of su(2), although this claim is not universally accepted.
  • A later reply points out a potential typo in the constructed basis, indicating ongoing refinement of the presented ideas.
Participants express differing views on whether so(4) can be represented as su(2) ⊕ su(2), particularly distinguishing between complex and real Lie algebras. The discussion remains unresolved, with multiple competing perspectives on the matter.
Participants highlight the importance of the underlying field (real vs. complex) in determining the relationships between the Lie algebras. There are also indications of missing assumptions regarding the bases used and the implications of isomorphisms.
Anthony
Hi guys - long time reader first time poster!
I'm currently getting to grips with the topic of Lie Algebras, and I've come across something that's baffled me somewhat. I've been asked to show:
[tex]so(4) = su(2) \oplus su(2)[/tex]
Where the lower so(n) denotes the Lie Algebra of SO(n) etc. Now, in a previous question, I was asked to show:
[tex]u(2) = su(2) \oplus \mathbb{R}[/tex]
Where [tex]\mathbb{R}[/tex] denotes the set of constant (real) multiples of the matrices of the form [tex]i\mathbb{I}_2[/tex]. This was easy enough; I showed that for each [tex]v\in u(2)[/tex] there exists a [tex]x \in su(2)[/tex] and a [tex]y \in \mathbb{R}[/tex] such that v=x+y, and also that if [tex]A \in su(2) \cap \mathbb{R}[/tex] then A=0.
However, in this new case, I assume the [tex]\oplus[/tex] means the the matrix direct sum, but surely if this is the case, then it's false - since the matrices in so(4) take the form:
[tex]\left(\begin{array}{cccc}0&a&b&c\\-a&0&d&e\\-b&-d&0&f\\-c&-e&-f&0\end{array}\right)[/tex]
Which is not of the form of a matrix direct sum. If anyone could give me any hints as to where my confusion lies, I'd be very greatful - although if you could keep the hints sufficiently vague, as to not to do all the work for me!
Actually, I should add. My only (perhaps?) contructive thought was the existence of a certain isomorphism which takes su(2) to a subset of so(4). For a general [tex]v \in su(2)[/tex] we have:
[tex]v = \left(\begin{array}{cc}ia&ic+b\\ic-b&-ia\end{array}\right) = \left(\begin{array}{cc}0&b\\-b&0\end{array}\right) + i\left(\begin{array}{cc}a&c\\c&-a\end{array}\right) = A + iB[/tex]
Then there is an isomorphism G such that:
[tex]G(v) = \left(\begin{array}{cc}A&-B\\B&A\end{array}\right)[/tex]
Since we have:
[tex]G(v_1 v_2) = \left(\begin{array}{cc}A_1 A_2 - B_1 B_2&-(A_1 B_2 + B_1 A_2 )\\A_1 B_2 + B_1 A_2&A_1 A_2 - B_1 B_2\end{array}\right) = \left(\begin{array}{cc}A_1&-B_1\\B_1&A_1\end{array}\right)\left(\begin{array}{cc}A_2&-B_2\\B_2&A_2\end{array}\right) = G(v_1)G(v_2)[/tex]
And so:
[tex]G([v_1,v_2]) = [G(v_1),G(v_2)][/tex]
But this doesn't give me all of so(4).
Are you working with real or complex Lie algebras?
It is true that for complex Lie algebras,
[tex] so_{4} \mathbb{C} \cong su_{2} \mathbb{C} \oplus su_{2} \mathbb{C},[/tex]
but I don't think that a similar relationship holds for the real Lie algebras so(4) and su(2).
The set of matrices
[tex] \left\{\left(\begin{array}{cc}i&0\\0&-i\end{array}\right), \left(\begin{array}{cc}0&i\\i&0\end{array}\right), \left(\begin{array}{cc}0&1\\-1&0\end{array}\right)\right\}[/tex]
is a basis for both the real Lie algebra su(2) and the complex Lie algebra [tex]su_{2} \mathbb{C}[/tex]. In the former, all real linear combinations of basis elements are allowed; in the latter, all complex linear combinations of basis elements are allowed.
If you would like, I will give some broad hints in a future post.
Regards,
George
Have you considered that there might be more than one basis you can think of?
the latex for setting lie algebras is \mathfrak{text}, though i don't know if we support it here:
[tex]\mathfrak{sl}_2[/tex]
incidentally, sl_2 and so_3 are the same lie algebra, but if you pick the standard basis they dont' look it.
Apologies George - I should have said, the Lie Algebras are complex. Any hints (however vague) would be much appreciated. :)
Hmmm, ok - so at the moment I'm considering a basis of [tex]\mathfrak{so}(4)[/tex] of the form:
[tex]\left{\left(\begin{array}{cccc}0&1&0&0\\-1&0&0&0\\0&0&0&0\\0&0&0&0\end{array}\right), \left(\begin{array}{cccc}0&0&1&0\\0&0&0&0\\-1&0&0&0\\0&0&0&0\end{array}\right), \quad \textrm{etc.}\right}[/tex]
But perhaps if I think about suitable combinations of these, I'll get something more like the form I'm looking for?
The help is much appreciated guys. :)
In more detail: the real Lie sl(2,C) has a complex structure. When this is taken into account, sl(2,C) with complex structure is isomorphic to the complexification of the real lie algebra so_3.
This is why angular momentum theory in physics quantum theory texts looks like the representation theory of sl_2 given in math texts.
Regards,
George
Well, I thought I'd get back to you guys and let you know it's all sorted. Here's how I went about it:
1) Contruct a basis for [tex]\mathfrak{so}_4[/tex] with the following matrices:
[tex]\left\{ \left{\left(\begin{array}{cccc}<br /> 0&1&0&0\\<br /> -1&0&0&0\\<br /> 0&0&0&1\\<br /> 0&0&-1&0\end{array}\right), <br /> \left(\begin{array}{cccc}<br /> 0&0&0&1\\<br /> 0&0&-1&0\\<br /> 0&1&0&0\\<br /> -1&0&0&0\end{array}\right),<br /> \left{\left(\begin{array}{cccc}<br /> 0&0&1&0\\<br /> 0&0&0&-1\\<br /> -1&0&0&0\\<br /> 0&1&0&0\end{array}\right), <br /> \left(\begin{array}{cccc}<br /> 0&0&-1&0\\<br /> 0&0&0&-1\\<br /> 1&0&0&0\\<br /> 0&1&0&0\end{array}\right),<br /> \left{\left(\begin{array}{cccc}<br /> 0&0&0&1\\<br /> 0&0&-1&0\\<br /> 0&1&0&0\\<br /> -1&0&0&0\end{array}\right), <br /> \left(\begin{array}{cccc}<br /> 0&-1&0&0\\<br /> 1&0&0&0\\<br /> 0&0&0&1\\<br /> 0&0&-1&0\end{array}\right) \right\}[/tex]
Which I'll refer to as [tex]\left\{ a_1, a_2, a_3, b_1, b_2, b_3 \right\}[/tex]. Then upon computing the Lie brackets, we see:
[tex][a_i, a_j] = \epsilon_{ijk} a_k \qquad [b_i, b_j] = \epsilon_{ijk} b_k[/tex]
And so [tex]\left\{a_i\right\} \cong \mathfrak{su}_2[/tex] and also [tex]\left\{b_i\right\} \cong \mathfrak{su}_2[/tex]. Since [tex]\mathfrak{so}_4={a_i} \oplus {b_i}[/tex] we have:
[tex]\mathfrak{so}_4 \cong \mathfrak{su}_2 \oplus \mathfrak{su}_2[/tex]
Which I think is ok.
a_2 = b_2. Is this just a typo?
Regards,
George
Sure is (too many matrix elements!). It ([tex]a_2[/tex]) should be:
[tex]\left(\begin{array}{cccc}<br /> 0&0&0&1\\<br /> 0&0&1&0\\<br /> 0&-1&0&0\\<br /> -1&0&0&0\end{array}\right)[/tex]
  • · Replies 22 ·
  • · Replies 19 ·
