What is the physical significance of the energy triangle in particle physics?
  • Context: Graduate
  • Thread starter Thread starter Carolina Joe
    Energy Triangle
The discussion centers around the physical significance of the energy-momentum relationship in particle physics, specifically the equation E² = (m₀c²)² + (pc)². Participants explore whether this relationship has deeper implications or if it is merely a coincidental mathematical expression. The scope includes theoretical interpretations, historical context, and mathematical reasoning related to energy and momentum in particle physics.
  • Historical
  • Some participants propose that the energy-momentum relationship can be interpreted as a right triangle, with total energy as the hypotenuse and the other two sides representing rest mass energy and momentum.
  • Others argue that this relationship may not have significant physical meaning and could be coincidental, suggesting that E cannot be considered the hypotenuse in a meaningful way.
  • A participant mentions the historical use of trigonometric tables by physicists in the mid-20th century to calculate energy and momentum, indicating a practical application of the triangle concept in particle physics.
  • Another participant introduces the idea of a geometrical interpretation of time and space in relation to the energy-momentum relationship, discussing the concept of proper time and slack in a string analogy.
  • Some contributions highlight the ambiguity in defining trigonometric ratios in relation to the triangle formed by energy and momentum, emphasizing the need for clarity in physical descriptions.
  • A later reply questions the uniqueness of the trigonometric definitions and suggests that multiple interpretations exist depending on how the triangle is drawn.
Participants express a mix of views, with some supporting the idea of a geometrical interpretation while others contest its significance. There is no consensus on whether the relationship has deeper physical meaning or is merely coincidental.
Participants note limitations in their understanding of advanced concepts, such as Minkowski spacetime and its implications for the energy-momentum relationship. Some discussions also reflect on the historical context of calculations in particle physics, which may influence current interpretations.
Carolina Joe
Energy "Triangle"
It seems to me that the total energy of a particle forms a kind of right triangle.
[tex] E^2 = (m_0 c^2)^2 + (pc)^2[/tex]
Where the total energy is the hypotenuse, and it's square is the sum of the other 2 sides, each squared. Does anyone know of any physical significance to this fact, or is it just a coincidental relationship that has no further meaning? I just love stuff like this.
Modify the equation to
[tex](m_0 c^2)^2 = E^2 - (pc)^2[/tex]
This is the magnitude of the momentum-energy four-vector expressed - by the pseudo-Pythagorean rule of Minkowski spacetime - in terms of its timelike, E, and its spacelike, pc, components. The magnitude of a four-vector is the same in all intertial frames, and the magnitude of the momentum energy four-vector is mc^2 (m being the invariant mass).
Ah, so the triangle-like quality of that expression is useful, but in an area of physics I've never studied. My texts are undergraduate level, so I guess if you're looking at graduate textbooks they go further into special realativity using Minkowski spacetime? Is that just a framework for working in relativity? I've got a lot to learn. What makes E the timelike element, and pc spacelike?
I like your question very much and it is not any kind of question. As you just guess it this so called momentum-energy relation has really no physical significance and this relationship is just coincidental..The energy E cannot be the hypotenuse but actually I've just come to the oint that p& E are perpendicular
In the 1950's and 1960's, before the advent of electronic (and pocket) calculators, physicists used trigonometric (sin, tan, cotan, cos) tables (for 90-degree right triangles) in math books to calculate energy and momentum of particles in beamlines; e.g., E sin(theta) = pc, where beta = sin(theta). Also, cos(theta) = sqrt(1-beta2), and E cos(theta) = rest mass. Luis Alvarez I think was one of the earliest to have a HP-35 pocket calculator in the late 1960's, the earliest pocket calculator to have trig, log, and exponential functions.
The corresponding relationship between time, space and proper time does have a geometrical triangle interpretation, as follows:
Take two space-time events and connect them in space with a piece of string of length ct, representing the time between them. The proper time between those events is then given by the slack in the string, specifically by the maximum perpendicular distance that one can move the mid-point of the string from one side to the other of the path (on the assumption of constant velocity between the events). Note that if the separation is null, the string is straight and there is no slack. If the two events are at the same point in space, the slack is equal to the length of the string and the proper time is equal to the time.
Note that if you subdivide or join these pieces of string to cover additional events, the lengths (corresponding to time) add linearly and so do the displacements between their ends (corresponding to space), but the way the slack adds depends on whether the events fall on a line of constant velocity. If they do, the sum of the slack (proper time) for each part still adds up to the total for the end events, but if there is a change in velocity involved, the total slack is less than that between the end events for the overall path.
In the plain (p,E) this equation describes a known hyperbola E(p).
At the same time E(p) is numerically the distance from the reference frame point (0,mc^2) to the point p in the axis p.
Bob.
Dear Bob,
The trigonometric equation you give don't define the ratio E/pc of a uniquely manner.It all depends on which corner of the triangle you take.For example you can also have cos(theta)=E/pc, that means you always have to draw a triangle in order to show to the reader which angle you are talking about. And this is not Physics. The laws and equations of nature must be described in a uniquely manner.
[Bob S]
ahdaf said:
Dear Bob,
You are correct in that there is more than one way to define what sin(theta) and cos(theta) are. My convention has been to draw m0c2 along the positive x-axis beginning at the origin. I then draw "pc" up vertically along the y direction from the x-axis at point "m0c2". I then draw "E" from the origin up diagonally to the end of pc. This forms a right triangle, with a slope = sin(theta) = beta. Let's try both methods. Suppose beta = 0.5. What is sqrt(1-beta2). The answer is, using my pocket calculator, 0.866025. Now use trig tables. I find sin(theta)=0.5, and cos(theta)=0.86603. Now let's do it backwards; I look up cos(theta)=0.5, and then sin(theta) = 0.86603!. So it doesn't matter which way I do it. Which way did you do it?
Bob S said:
[Bob S]
I really appreciate the way you say the thing and I liked your first sentence you started with your quote and want you to have a look again at it. You said " there is more than one way to define..." and precisely this shouldn't exist. There should only one way to define thing without any ambiguities.Take this example. If you tell me find the work done by a force F during a displacement L, I know that I have to write W=F.L cos(F,L) and I don't need you to assist me about the angle between F and L. Another example if you have to find the torque of F about a certain point distant r from F. Here you just go and write T=rxF=rFsin(r,F). That is you know already that the angle is between r&R and anyone else.
The lack of ambiquity is that If I look up beta in the trig table under either sin (or cos), then sqrt(1-beta2) is found in the trig table labelled cos (or sin). I can also look up sqrt(1-beta2) in sin (or cos), and find beta under cos (or sin). This is not ambiguity. It is sometimes labelled degeneracy (like multiple atomic states having same energy). This has nothing to do with torque.
I am looking for the origin of the energy triangle. Books refer to Einstein, but I have not found a specific reference. I failed to find it with the help of Google. Has anyone seen a specific reference?
Do you mean the historical origin, i.e. who first used it and when? Or are you looking for a derivation of it?
Just a reference to the historical origin.
  • · Replies 59 ·
232K
  • · Replies 40 ·
  • · Replies 27 ·
  • · Replies 131 ·
13K
