Qn5What is the purpose of using a self-biased circuit for MOSFET amplifiers?
The discussion revolves around the biasing of MOSFETs for use as amplifiers, particularly focusing on the design of DC biasing circuits, the operational regions of MOSFETs, and the differences between enhancement and depletion type MOSFETs. Participants explore the necessary conditions for biasing, the implications of different biasing methods, and the small signal equivalent circuit models.
  • Some participants explain that MOSFETs need to be biased in the saturation region for proper amplification, contrasting this with BJT biasing methods.
  • There is a discussion about the equation for drain current in saturation, with some participants providing variations of the equation and discussing the parameters involved.
  • Questions are raised regarding the differences in DC biasing design between n-type enhancement and n-type depletion MOSFETs, with some participants suggesting that the main difference is the threshold voltage.
  • Participants discuss the small signal equivalent circuit models for enhancement and depletion MOSFETs, with one participant asserting that the models are essentially the same except for the sign of Vgs.
  • There is a debate about why the linear approximation of drain current is used instead of the quadratic equation, with some participants noting that the linear approximation simplifies circuit design but is less accurate for larger voltage swings.
Participants express various viewpoints on the biasing of MOSFETs, with some agreeing on the need for saturation and the significance of threshold voltage, while others present differing interpretations of the small signal models and the implications of linear approximations. Overall, multiple competing views remain, and the discussion does not reach a consensus.
Limitations in the discussion include the dependence on specific definitions of terms like threshold voltage and the conditions under which linear approximations hold true. There are also unresolved mathematical steps regarding the derivation of certain equations.
cyeokpeng
Hi,
I know how to bias a BJT transistor to operate in the active region, so that the amplifier circuit can operate as a small-signal amplifier. Two methods
(i) Use biasing resistors to form a self-biasing circuit.
(ii) Use diode biasing, coupled with biasing resistors.
Qn1
However, how do we bias the transistor circuit to act as small signal amplifier, if MOSFETs are used instead?
Design of dc biasing circuit for MOSFET as an amplifier?
I read from my textbook that we need to bias the MOSFET in the saturation region, which is quite different from the BJT amplifier dc biasing design.
The relation of MOSFET in saturation region is
Id = K(Vgs - Vt)^2
where Id = dc drain current
K = a property of MOSFET (What exactly is this?)
Vgs = dc gate-source voltage
Vt = threshold voltage of MOSFET
Qn2
Is there any difference in dc biasing design of n-type enhancement MOSFETs with n-type depletion type MOSFETs? What is the difference?
Qn3
After the MOSFET biasing point is fixed (saturated), we input an small ac signal in the input port, to get an amplified output signal in the output port, with the midband gain depending on the amplifier design.
How is the small signal equivalent circuit model different for enhancement and depletion type MOSFETs?
My answer is, they are essentially the same, but with one slight difference:
vgs for enhancement type is positive, while vgs for depletion type is negative, am I correct?
Qn4
In the small signal model of MOSFET, the ac drain current
id = transconductance * vgs ---Linear, voltage-controlled current source
Why is it this formula, and NOT Id = K(Vgs - Vt)^2?
transconductance = 2K(Vgs - Vt) --Enhancement and Depletion type MOSFET
U have to bias the MOSFET to have the full output swings. choose your bias point so that in any case it should not go out of saturation.
the equation for mosfet in saturation region is
Id=1/2 U Cox W/L(Vgs - Vt)^2
where U = mobility, Cox= capacitance and W/L = width and legth of mosfet
if u put the value of transconductance in current equation which a reverse of resistance in triode mode...u will get the value of same formula
Q1) To bias a MOSFET the voltages from the gate to source and from the gate to drain need to be regulated. The device operates in saturation when the gate to source voltage Vgs is greater then the threshold voltage and when the gate to drain voltage is less then the threshold voltage of the transistor. Both conditions must be satisfied.
Q2) The only difference between depletion and enhancement MOSFETS is the value of the threshold voltage, at least its the difference you care about in circuit design.
Q3) Your answer is right
Q4) You do not use Id = K(Vgs - Vt)^2 because you are using a linear approximation of Id = K(Vgs - Vt)^2. If Vgs is only changing by 1mV then the current Id will change in an almost linear way. The linear approximation allows circuit design to be much simpler by only working with linear equations rather then quadratic equations. Keep in mind that it is an approximation though, the larger the voltage swing at the input of the amplifier the less accurate the approximation is.
nMOS ENHANCEMENT mode is when you aply positive voltage at the gate and it form a channel under the gate ...so it attracts the electronwhereas when u apply negative voltage ta the gate , it actually deplete the region under gate bacoz of negative supply...
For analog design circuit, u have to keep the device in saturation mode in case...coz to set the threshold voltage in triode is very difficult.
