I Quantum Entanglement and Synchronization
  • Thread starter Thread starter James Hasty
Quantum entanglement cannot be used to synchronize clocks as it would imply faster-than-light signaling, which is not possible. While the concept involves measuring entangled particles A and B to set clock times, this misunderstands the nature of quantum entanglement. The measurement of one particle does not provide information about the state of the other until it is measured, making synchronization unfeasible. A recent study demonstrates quantum clock synchronization over a distance, but it does not validate the proposed mechanism of using entangled particles for clock synchronization. The discussion highlights the complexities and limitations inherent in quantum mechanics.
James Hasty
TL;DR
Can Quantum Entanglement be used as a means to Synchronize Clocks?
Given two quantum entangled particles A and B, let each be located inside one of two identical clocks. Let each clock be set to zero time the instant either particle A or B is measured or changes state. Could this mechanism be utilized to synchronize the clocks?
Evidently this has been proven possible. See the following article:
Tang, BY., Tian, M., Chen, H. et al. Demonstration of 75 km-fiber quantum clock synchronization in quantum entanglement distribution network. EPJ Quantum Technol. 10, 50 (2023). https://doi.org/10.1140/epjqt/s40507-023-00207-9
James Hasty said:
TL;DR Summary: Can Quantum Entanglement be used as a means to Synchronize Clocks?
No, that would require faster than light signaling. This is not possible.
The mechanism described there is not what you propose in your original post.
Likes James Hasty and pines-demon
I guess your idea is to measure A and simultaneously B "changes state", which is instantly observed by clock B.
That misunderstands quantum entanglement. There is no way to know by observing B when A has been measured.
No. There is no way of distinguishing a so-called collapsed state from an uncollapsed state (the “so-called” is there because even trying to make that distinction betrays a fundamental misunderstanding of the theory). All we know is the time that we made our measurement, and with our result we can predict the result at the other end when and if that measurement is made (and for all we know, it has been already made).
Likes James Hasty and PeroK
Thank you all for your replies.
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 31 ·
