What researchers think of the Coriolis force
The discussion centers on the complexities of teaching the Coriolis force and its effects on motion across the Earth's surface. Jared Arnell highlights the inadequacies of conventional teaching methods, while Boyd Edwards emphasizes the confusion surrounding the Coriolis force, even among renowned physicists. Anders Persson advocates for a teaching approach that combines apparent and real forces, rather than solely focusing on the Coriolis force. This multifaceted perspective aims to enhance students' understanding of motion in a rotating frame.
  • Understanding of classical mechanics, particularly Newton's second law.
  • Familiarity with rotating reference frames and their implications.
  • Knowledge of centrifugal force and its relationship to the Coriolis force.
  • Basic grasp of kinematics and dynamics in physics.
  • Research the mathematical transformation of Newton’s second law in rotating frames.
  • Explore the relationship between centrifugal force and Coriolis force in motion analysis.
  • Study the pedagogical approaches to teaching complex physical concepts in mechanics.
  • Investigate real-world applications of the Coriolis effect in meteorology and oceanography.
Physics educators, students of classical mechanics, and anyone interested in the dynamics of motion on rotating bodies will benefit from this discussion.
Simon F
TL;DR
A list of citations from researchers in physics and geosciences of the last decade on what is known and what is incorrect about the Coriolis force.
"It is clear that the conventionally available conceptual methods for
teaching how the Coriolis force affects motion across the surface of the earth are too
infrequent, inaccurate, or incomplete to construct the desired conceptual mastery."
Jared Arnell, student of Boyd Edwards, 2022
https://digitalcommons.usu.edu/etd/8509/
"Despite its long history of study, the Coriolis force is a
continuing source of confusion, including errors by Richard
Feynman and Max Born. The Coriolis deflection can
seem downright mysterious, as anyone who has played catch
with a ball on a merry-go-round can attest. Students of
intermediate (upper-division) classical mechanics learn how
to transform Newton’s second law into a uniformly rotating
frame mathematically, but they often cannot interpret the
mathematics, appreciate the physical origins of the Coriolis
and centrifugal forces, or relate them to motion as seen by an
observer in the inertial frame."
Boyd Edwards, 2021
https://pubs.aip.org/aapt/ajp/artic...aws-for-motion-on-our?redirectedFrom=fulltext
"It would perhaps have expressed more strongly his concern that the 2Ω × Vr term was a kinematic description only of how the oscillation performed, not why. To accomplish this he made a dynamic analysis which gave the result that the gravitational attraction, a very real force, was highly instrumental in the ‘inertial’ oscillation."
Anders Persson, 2015
https://rmets.onlinelibrary.wiley.com/doi/abs/10.1002/qj.2477
"In contrast to the traditional approach, the deflection as observed on a rotating planet should not be treated as the consequence of one fictitious force, the Coriolis force, but instead as a combination of apparent and real forces. Teachers should show that the centrifugal force, mathematically and physically intrinsically coupled to the Coriolis force, has to be neutralized or balanced."
Anders Persson, 2020
https://elibrary.ru/item.asp?id=50122349
I usually call it the "Coriolis Effect", although wiki uses "Coriolis Force" as the title.
I think its best to be able to see it both ways.
As for what exactly is taught, that would depend on the specific course objectives. Explaining how weather fronts move across the Earth's surface from the point of view of an Earth-bound observer is very practical.
Actually the Corolis effect becomes a force when the inertia oscillation (or Coriolis-only motion) turns into a force instead of remaining a free process. This means that the centripetal force of the inertial frame of reference is also the resistance of the Coriolis-only motion facing adverse effects. In a rotating frame of reference, the Coriolis force is then the same physics: it expresses the resistance of the Coriolis-only motion facing adverse effects. In a rotating frame, forces are not Newtonian but the Coriolis-only motion resistance is a physical process. Just try to move a heavy mobile while rotating and you will feel what is this Coriolis-only motion resistance.
A couple of years ago, one of my Physics I students was a graduate of US sniper school- he knew that the Coriolis force had to be corrected for when long-distance shooting, but (prior to class discussion) didn't understand why or what.
Geometricians and rotating observers may appreciate the geometric significance of the Coriolis term but recall that the simple fact of rotating the frame of reference creates a complex term and not a Coriolis-only motion.
You need a centripetal force for the Coriolis-only motion and the deflection for a rotating observer will be then much stronger than in the previous case. A key aspect for ballistics would be to know whether the projectile feels or not a centripetal force directed to the Earth's axis.
The difference between the "no centripetal force" (aka centrifugal unbalanced) and the "centripetal force" (aka centrifugal balanced) cases is given here:
Tons of illustrations in common educational stuff are "no centripetal force" but the importance of the Coriolis term in physics is due to a centripetal force work and the associated Coriolis-only motion, or at least, an attraction/resistance towards this motion.
Other visual demonstrations of the Coriolis-only motion
It only just struck me that the fictional Coriolis force on the bullet could be regarded as a fictional 'reaction' force on the Earth but a much higher value. So not equal and opposite; just opposite. You could imagine trying to land on an aircraft carrier when it's following a curved course; massive force on the ship's rudder but relatively small correcting force needed on the plane. (or, indeed, the force needed on a non rotating Earth to give the impression of Coriolis on an airliner.)
