Transit time for a round trip to Alpha Centuri...
  • Level: Undergrad
  • Thread starter Thread starter oracle99
47 replies · 5K views
oracle99
TL;DR
A simple relativity question.
Just a simple little question as my first post here..
Suppose you have a space craft that has an engine that can exert an acceleration of 1G. You fly this to Alpha Centauri accelerating, then halfway turn around and decelerate at 1G, so you have gravity for the whole trip.
Once you arrive, you turn around and fly back home the same way.
How long would appear to elapse for the traveler, and how long would appear to elapse for people on Earth? What is the formulea for different accelerations?
Using Earth time and starting from rest, distance travelled in time ##t## at constant acceleration ##a## is ##s=\frac 1a(\sqrt{1+a^2t^2/c^2}-1)##.
Note that if you use light years for distance and years for time then ##c=1## and 1g is within 5% of 1 light year per year squared, so ##s\approx\sqrt{1+t^2}-1## and each two light year phase of the journey takes about ##\sqrt{8}\approx 2.8## years. So 5.7 years all the way there, and 11.3 for the round trip.
Ship board time, ##\tau##, is related to Earth time, ##t##, by ##\tau=\frac ca\sinh^{-1}(at/c)##. Again setting ##c=1## and ##a\approx 1##, ##\sinh^{-1}(2.8)\approx 1.76## for each two light year phase, so 3.5 years to Alpha Centauri and 7 years for the round trip.
I assume the acceleration here is measured in the spaceship time and distance, since the OP wants it to feel like Earth's 1g to the travelers.
Yeah, ##a## is proper acceleration here.
You can't maintain a Minkowski coordinate acceleration of 1g for more than a year(ish) anyway, even in principle, since you'd reach lightspeed at that point.
So if you travel 3 years you get
sqrt(3*3+1)-1= 2.16 light years, about half way to Alpha Centauri, so decelerate is the same, so approx 6 years out, 6 years back, 12 years, from the travelers perspective?
oh I see you updated it, that would be earth dwellers time. Thanks!
Another little point, there is often discussion about traveling faster than the speed of light - you can, but the people back home won't see it that way!
No, you can't.
You can't outrun a light ray that's moving in the same direction as you are. That's not a matter of who is "seeing" it; it's an invariant fact.
There are ways to calculate a "speed" that will give a result greater than ##c##, but given the above fact, describing any such calculation as showing that anything is "moving faster than light" is problematic.
No, you can't. With reference to the traveler's restframe, the distance between Earth and Alpha Centauri is length-contracted, which explains for him the short proper travel-time.
If you divide the distance to Alpha Centauri (4ly) by the shipboard elapsed time (3.5y) you will get a value greater than ##c##, yes, and you can use this fact to get to distant places in your lifetime (although not that of your friends at home). However, this isn't a speed - it's a (rather useless) quantity called celerity (or average celerity in this case, since the speed isn't constant). The celerity of light is infinite, so your celerity is always less than that of light.
Note that the fuel requirements even for the relatively modest trip we're talking about are absurd.
The key physical fact is that nothing ever overtakes a light pulse, no matter how you play with the numbers.
I understand that the traveller is not literally travelling faster than light, just that you would percieve that, in that time frame.
And yes, the practical problems in actually doing it are massive, and even if you are very close to a "perfect" engine, you need to carry insane amounts of fuel.
One idea I liked was to use a powerful solar powered laser sited near the sun, and a solar sail, which avoids carrying fuel, but requires a similar setup at the other end to slow down.
Our first interstellar travellers are likely to be AI robots.
How?
Not if you do the maths consistently, I'm afraid. I think you're comparing the ship's celerity to light's velocity, which is a similar mistake to thinking two feet must be longer than one meter because 2>1.
Just to add, accidentally mixing measurements made using different frames is one of the more common reasons people end up confused about relativity. So it's something we recommend against, even half-jokingly.
By the way, this is basically why you'll very rarely find the word "celerity" outside a passing mention in some relativity textbooks. It's mixing one frame's distance measurement with another's time measurement.
In the original question I made a point if returning the traveller to the original frame of reference, earth.
Obviously i bow to your superior knowledge, but maybe there is a misunderstanding? The above calculation says the traveller will see 3.5 years pass when travelling 4 light years..
Time and fuel problems aside - great discussion! Gives me goose bumps just to see us starting to think seriously about interstellar travel. And that it's 'do-able' at least from a traveler's time perspective.
Not every calculation is physically meaningful.
Consider that a light ray emitted from earth at the same time that the spaceship leaves earth will arrive at alpha centauri before the spaceship.
The frame where the traveller sees 3.5 years pass is his rest frame, so he doesn't travel any distance at all (his destination comes to him). The frame where he's travelled 4ly is not his rest frame, so he shouldn't be using his moving clocks to calculate his speed (if he does, he's calculating his celerity, not his speed).
It is possible to do consistent calculations where either Alpha Centauri or the traveller have something-like-a-speed that exceeds ##c##, but those same calculations should then be applied to light and you will find its something-like-a-speed exceeding ##c## by an even greater margin. To put it another way you can, in some senses, go faster than ##c##, but you can never go faster than light.
As I said in #10, the traveller can certainly exploit time dilation to arrive at his destination with less time elapsed on his clocks than the four years Earth measurements would say light needed. But interpreting this as faster than light travel is an apples to oranges comparison, and it leads into a lot of common misunderstandings of relativity so we strongly recommend against it.
Yes, I understand it is only percieved time elapsed, the traveller cannot actually travel faster than light.
This is an important point if we consider speeds close to the speed of light. In principle, humans could make an interstellar trip and back in less of their own proper time than the distance divided by ##c##. There are several places online where the calculations associated with constant proper acceleration (and deceleration) at ##g## are presented.
However, getting to such speeds (by sustaining a constant proper acceleration) requires so much fuel, that perhaps a more realistic scenario is where the elapsed time on the ship is not crucial. In that case, a journey could take hundreds or thousands or years according to Earth or onboard time-keeping.
In any case, IMO, the calculation of the onboard elapsed proper time is perfectly meaningful.
To be clear (and please PFati correct me), its not a matter of merely perceiving.
Aboard ship, if they look out their front window, A.centauri will only be 3.5 ly away (because everything ahead of them is longitudinally squished). They will have no dissonance wondering why the trip only takes them 3.5 years.
At what point of their accelerated flight? They would have to explain why the distance got shorter than it originally was.
My two cents:
The travelers always think they are accelerating at 1g, whereas the Earthlings know that is impossible and the travelers are exerting more and more effort to accelerate less and less. That is why the travelers think they are going faster and take less time.
ADDED: After thinking more about it, my "two cents" may not have been worth that much. I will not comment further.
Yes. I was oversimplifying. One could more accurately argue that, at the midpoint, A.centauri is only 1.75ly away, which is why the second leg of the journey only take 1.75y and not 2.15y.
Yes. It's not like they are ignorant of relativity. The point I'm making is their reduced journey is not merely a "perception" issue, as oracle might have been implying.
FactChecker said:
My two cents:
This is another perspective yes. But less useful, in my view.
The point I'm trying to make for the OP, is that the experience of the ship's occupants is no less real - no more illusory, and no more paradoxical - than the experience of those on Earth.
The question is how you measure distance and how you interpret your instrument readings. Probably the easiest way to do things is radar. The standard way to interpret that, though, would mean that Alpha Centauri starts moving four years before the traveller turns on his rockets, so there are 7.5 years (ship time) for it to make the trip.
The reason you interpret Alpha Centauri as accelerating before you do is that the radar pulse flight time is initially constant, but starts to fall the instant you turn on your rockets. And you know the radar pulse returning as you hit the big red button echoed off Alpha C four years ago - ergo you interpret it as starting to move four years ago.
The maths for this isn't terribly complicated, but more than I have time for this morning.
It doesn't matter whether you look out the window or not. Alpha Centauri is about 4.4 light years from Earth, but it's possible to travel there and age less than 4.4 years. How much less depends on the practicalities of interstellar travel. In terms of the physics, there is no lower limit.
The main point is that the initial distance divided by the on-board travel time is not a speed to be compared with the speed of light. As measured on Earth, it must take at least 4.4 light years travel time. That can then be compared with the speed of light from Earth to AC.
Squishing and dissonance are not what it's about! Those words belong in your literary endeavours!
*sigh* All I'm trying to do is dispel Oracle's notion, here:
...that the spaceship occupant's experience is somehow less real, more illusory than Earth's experience.
If an occupant woke up from sleep and did not know they were travelling at .99c, they could still look at their destination and see that it is 1.76ly away and moving toward them at .99c. If they turn their rocket around and start accelerating (to match velocities with it) they could accurately determine that they will arrive in the correct time.
His journey aboard the spaceship is not merely "perceived" time.
How would they "see" that?
There's coordinate time and proper time. I guess that "perceived" time could be taken to be the proper time aboard the spaceship.
No it doesn't. It shows that 3.5 years pass. You're assuming (incorrectly) that 4 light years is the distance traveled.
