Doubt regarding X-rays
  • Level: High School
  • Thread starter bananakicker456
9 replies · 6K views · last reply
bananakicker456
Hello everyone. My question is that can an electron if incident (on say, a metal ) with enough energy knockout another electron (of the metal atom)?. I know that atomic excitation can occur causing atomic electron to jump to higher energy level (bohr s model), but staright up knockout and then later form x rays? if yes, then is there a formula to derive the minimum amout of energy needed to do it, and is my claim even correct?
Welcome to PF.
Easily, when an electron hits a target it may be absorbed, produce a photon of light, or another electron with a similar energy.
If you remove an electron from the surface of a metal, and then accelerate it through a voltage difference of 1 volt, it will gain an energy of 1 eV, (one electron volt). When that electron impacts a metal target, it may release that energy as a photon. The wavelength (colour) of that photon is inversely proportional to its energy.
but straight up knockout and then later form x rays? if yes, then is there a formula to derive the minimum amount of energy needed to do it,...
If you specify the required wavelength, λ, you can work out the voltage difference needed to accelerate the electron to get a photon of that wavelength.
Energy; eV = 1239.84 / λ nm
X-rays have a wavelength of about 30 pm = 0.03 nm, so the required energy is 1239.84 / 0.03 = 41.3 keV, which will require a voltage of 41.3 kV. X-ray machines operate between about 20 kV and 80 kV.
To produce red light, λ = 700 nm. V = 1239.84 / 700 = 1.77 volts.
That is the voltage needed to light a red LED.
.... but staright up knockout and then later form x rays? if yes, then is there a formula to derive the minimum amout of energy needed to do it, and is my claim even correct?
Aren't the energy levels of electrons in an atom usually given relative to an electron outside of the atom (or at infinity)? Those would be the energies that you need to kick the electron out of the atom.
i mean yeah. energy values are the amount of energy needed to free the electron (take it to infinity).
Baluncore said:
Welcome to PF.
alright thank you so much
Exactly. So for the minimum energy needed to kick an electron out of the atom, look up the highest electron energy level (negative number closest to zero) for the specific element. When this hole is filled again by a slow electron, the photon emitted will have that energy.
yes i know that. my core question was that, " can an electron actually do that?" and i have got my answer. thank you
Sure, there is no upper limit on the energy an electron can have.
..staright up knockout ...
Actually, it can be very useful when that happens. As the other electrons are jumping around to fill up the hole the emitted radiation is highly specific to that atom. Look up 'XRF spectrometer' if you are interested.
a metal ... is there a formula to derive the minimum amount of energy
That also has it's own tricks. If you ask for metals (and some other materials) instead of atoms then the energy needed to make electrons depart can be very low (even some heating can do the trick).
You need x-rays only to reach deeper into the atoms.
The answer is certainly yes. One may wish to review the experiments of William Bragg and his son Lawrence at University of Leeds, and Henry (Harry) Gwyn Jeffreys Moseley of Trinity College, Oxford.
After working on a problem connected with beta-rays he became interested in the work that William Bragg and his son Lawrence were doing at Leeds. It was known that sharp X-ray lines were emitted by the target of an X-ray tube, and, using an X-ray spectrometer based on the Bragg's design, Moseley set about investigating how their wavelengths were related to the structure of the atom.
. . . Moseley devised an apparatus for bombarding samples of all the then available elements from aluminium to gold with electrons and measuring the wavelengths, and hence the frequencies, of the K and L lines in their spectra. He found that by plotting the square root of the frequency of the lines against a suitably chosen integer N a set of (almost) straight lines were produced.
https://www.physics.ox.ac.uk/about-us/our-history/highlights-archive/moseley-and-x-rays
William Bragg and his son Lawrence shared the Nobel Prize in Physics in November 1915. Sadly, Bragg's younger son, Robert died from his wounds received during the campaign in Gallipoli, Turkey in September 1915. Henry Moseley was killed at the age of 27 on the Gallipoli Peninsula on 10 August 1915.
X-rays are formed when an electron is 'knocked out' of an inner orbital ('shell') and another electron falls into that orbital. Electrons can be removed from atoms by photons, electrons or other charged particles. The incident energy must exceed the 'binding' energy of the particular electron. Moseley discovered that each atom has characteristic X-rays with energy related to the atomic number (charge of the nucleus = number of protons in the nucleus). Note that in order to remove an inner electron, an incident photon or electron must pass the outer electron(s) without losing energy; however, there is a probability that an incident photon or electron will interact with other electrons.
X-ray spectroscopy is a useful tool to evaluate which elements are present in a solid. X-rays and electrons are also used to interrogate the crystal lattice of a solid. The physics is well-established.
https://en.wikipedia.org/wiki/X-ray_spectroscopy
https://www.technologynetworks.com/analysis/articles/x-ray-spectroscopy-407245
