AlexOsipovich
- 7
- 1
- TL;DR
- I am currently studying the conceptual differences between Special Relativity (SR) and the historical Lorentz Ether Theory (LET) by working through a simple toy model. This is purely a conceptual exercise to understand where the mechanical interpretation of LET breaks down.
(This is not an attempt to promote or resuscitate the ether.)
I am working through a conceptual exercise about the historical Lorentz ether theory (LET), and I would like to check my understanding of its internal logic. I am not proposing a new theory. I am trying to see whether a literal reading of LET — where Lorentz contraction is treated as a real physical deformation of electromagnetic bonds — leads to any inconsistency when applied to a rotating heterogeneous body.
The setup is simple:
A rotor moves with the laboratory at some velocity relative to a hypothetical ether (say, the lab moves along the X-axis, so the ether wind is along X).
In LET, the rotor is contracted along X due to the anisotropy of the physical speed of light.
We then start rotating the rotor.
After a 90-degree rotation, the rotor presents a different orientation to the ether wind: it was compressed along its own X-axis, and now it should be compressed along its own Y-axis.
The "signal" for this re-compression travels at the speed of light, but the atoms are massive and cannot rearrange their positions at that speed.
If the rotor were monolithic, the re-compression would presumably occur without heat generation (the material simply relaxes to a new equilibrium). But in a composite rotor — a stiff frame plus a viscoelastic polymer — the two phases have different elastic moduli and different relaxation times. The polymer would respond differently to the changing equilibrium deformation, leading to a non-uniform stress distribution. The viscoelastic polymer might then dissipate energy as it lags behind the faster-responding stiff frame.
My question: within the mechanistic interpretation of LET (where contraction is a real deformation), should heat be generated in such a composite rotor? Or is there an argument why, even in that picture, no net dissipation should occur?
I am not claiming any such effect. I suspect there is a known reason why this toy exercise fails, and I would like to find the error or the relevant literature.
I can provide simple estimates if useful, but I have intentionally omitted experimental details because this is a conceptual/historical question. Any pointers to the relevant physics of viscoelastic composites or to historical discussions of LET would be appreciated.
