A possible Coasting Universe model vs ΛCDM
  • Context: Graduate
  • Thread starter Thread starter petergreen
    Model Universe
The discussion centers around the comparison of the Coasting Universe model with the ΛCDM model and Rh = ct models, particularly in relation to observations from Ia supernovae, galaxy correlation functions, and cosmic microwave background (CMB) events. The scope includes theoretical implications, potential explanations for cosmological observations, and the fundamental assumptions underlying these models.
  • Some participants propose that the Rh = ct universe model may provide a necessary explanation for the observed equality of the gravitational horizon and the distance light has traveled since the big bang, suggesting that this equality should hold for all cosmic time.
  • Others argue that the Coasting Universe model avoids the need for inflation and addresses several cosmological problems, such as the age of the universe and baryon density issues, while also suggesting it could explain discrepancies in the CMB power spectrum.
  • Some participants highlight that the Coasting Universe model may require exotic matter or new laws of gravity, raising concerns about its viability compared to the standard model.
  • There is a contention regarding the existence of dark energy in the Coasting Universe model, with some asserting that it does not exist, while others argue that a mechanism must counteract gravitational deceleration to achieve linear expansion.
  • Participants discuss the implications of the Dirac-Milne universe model, which posits a balance of matter and anti-matter to achieve linear expansion without dark energy.
  • Some contributions question the compatibility of the Coasting Universe model with CMB observations, suggesting that it may not fit well with current data.
Participants express multiple competing views regarding the viability and implications of the Coasting Universe model compared to the ΛCDM model. There is no consensus on which model is superior or more accurate, and the discussion remains unresolved.
Participants note various limitations and assumptions in the models discussed, including the need for exotic matter in the Coasting Universe model and the unresolved nature of dark energy's role in cosmological expansion.
This discussion may be of interest to those exploring alternative cosmological models, the implications of dark energy and dark matter, and the theoretical underpinnings of general relativity in cosmology.
petergreen
Two Coasting Universe model and comparison of the ΛCDM as well as Rh = ct models with Ia supernovae, GMB and CMB events. Both theory lead to the same result and fundamentals.
[Journal references below]
First model:
Rh = ct universe
"The backbone of standard cosmology is the Friedmann-Robertson-Walker solution to Einstein’s equations of general relativity (GR). In recent years, observations have largely confirmed many of the properties of this model, which is based on a partitioning of the universe’s energy density into three primary constituents: matter, radiation, and a hypothesized dark energy which, in ΛCDM, is assumed to be a cosmological constant Λ. Yet with this progress, several unpalatable coincidences (perhaps even inconsistencies) have emerged along with the successful confirmation of expected features. One of these is the observed equality of our gravitational horizon Rh(t0) with the distance ct0 light has traveled since the big bang, in terms of the current age t0 of the universe. This equality is very peculiar because it need not have occurred at all and, if it did, should only have happened once (right now) in the context of ΛCDM. In this paper, we propose an explantion for why this equality may actually be required by GR, through the application of Birkhoff’s theorem and the Weyl postulate, at least in the case of a flat spacetime. If this proposal is correct, Rh(t) should be equal to ct for all cosmic time t, not just its present value t0. Therefore models such as ΛCDM would be incomplete because they ascribe the cosmic expansion to variable conditions not consistent with this relativistic constraint. We show that this may be the reason why the observed galaxy correlation function is not consistent with the predictions of the standard model. We suggest that an Rh = ct universe is easily distinguishable from all other models at large redshift (i.e., in the early universe), where the latter all predict a rapid deceleration."
The Rh = ct Universe
http://arxiv.org/pdf/1109.5189.pdf
Fitting the Union2.1 SN Sample with the Rh = ct Universe
http://arxiv.org/pdf/1206.6289.pdf
The Rh = ct Universe Without Inflation
http://arxiv.org/pdf/1206.6527.pdf
Angular Correlation of the CMB in the Rh = ct Universe
http://arxiv.org/pdf/1207.0015.pdf
High-Z Quasars in the Rh = ct Universe
http://arxiv.org/pdf/1301.0017.pdf
The Gamma-Ray Burst Hubble Diagram and Its Cosmological Implications
http://arxiv.org/pdf/1301.0894.pdf
[Journal refs.: Monthly Notices of the Royal Astronomical Society (MNRAS) & Astronomical Journal - IOP Science]
Second model:
The model of a flat (Euclidean) expansive homogeneous and isotropic relativistic universe in the light of the general relativity, quantum mechanics, and observations
"Assuming that the relativistic universe is homogeneous and isotropic, we can unambiguously determine its model and physical properties, which correspond with the Einstein general theory of relativity (and with its two special partial solutions: Einstein special theory of relativity and Newton gravitation theory), quantum mechanics, and observations, too."
[Journal ref.: Astrophysics and Space Science]
The two theory fundamentals:
http://www.weebly.com/uploads/1/5/3/4/15349588/img3.gif
Space news on Phys.org
Nice articles going to take me a bit to go through them
I have argued for the benefits of the coasting cosmological model in the past.
Viz:
1. No need for Inflation; the horizon, density and smoothness problems that Inflation was developed to explain would not be there in the first place.
2. A natural explanation for the Age of the Universe = Hubble Time coincidence.
3. It alleviates any Age problem in the early universe.
4. The longer BBN epoch yields results in a higher baryon density that may explain Dark Matter as baryonic in nature. ( Must still be dark in the form of IMBHs perhaps). It would leave a Deuterium problem but resolve the Lithium Problem.
5. It would explain a low power deficiency in the CMB power spectrum when compared with the LCDM prediction.
First proposed by Kolb in 1989 as a way of avoiding Inflation A coasting cosmology , it was then taken up by an Indian team who found it a concordant alternative to LCDM. A Concordant “Freely Coasting” Cosmology, recently it has been advocated by Melia et al. in the papers cited in the OP.
There are problems, but no more than the standard model that has had to invoke Inflation, DM and DE, all unconfirmed in the laboratory.
Just a thought,
Garth
And this:
http://www.akamaiuniversity.us/PJST12_1_214.pdf
I would say the problems are vastly, vastly greater, as the coasting model requires either extremely exotic matter or an entirely new law of gravity.
And the [itex]\Lambda[/itex]CDM model does not? DM?? DE??
Linear expansion requires DE with an equation of state [itex]\omega = - \frac{1}{3}[/itex].
Kolb suggested K matter with [itex]p_k = - \frac{1}{3} \rho_k[/itex]
Such as might be provided by cosmic string networks.
As for an entirely new law of gravity, Self Creation Cosmology maybe??
(published in 'Horizons in World Physics, Volume 247: New Developments in Quantum Cosmology Research', Nova Science Publishers, Inc. New York)
Just a thought...
Garth
Dark matter isn't exotic at all by these measures. And [itex]\Lambda[/itex] has been a part of GR from the beginning (though it was usually assumed to be zero).
Yes. But detailed observations have now disproven the possibility that cosmic strings are a large fraction of the matter density of the universe.
I don't think you can fit the coasting universe with the CMB, at all.
Dear Chalnoth and Garth!
In the coasting universe, dark energy does not exist (Λ=0)! Only dark matter, onto which is the only possible candidate the weakly interacting axion, or the continuously and in increasing quantities generated, appearing and disappearing virtual particle pairs.
petergreen said:
Dear Calnoth and Garth!
In the coasting universe, dark energy does not exist!
Well that depends on how you obtain a coasting, i.e. strictly linear, expansion.
The empty universe, the Milne FRW model, contains no source of gravitation and therefore there is nothing to decelerate it, so it expands linearly.
If matter is present (as indeed there is) then that produces a gravitational field that would decelerate the universe. To obtain linear expansion something must counter act this effect.
In the Dirac-Milne universe equal amounts of matter and anti-matter exist and it is assumed that they repel each other. The universe instantly separates out into matter and anti-matter zones and this mutual repulsion cancels out the gravitational attraction within each zone.
Otherwise you need a medium of high negative pressure, otherwise known as dark energy and they are several hypothetical candidates that might be the source of this, the cosmological constant being one of them.
I hope this helps.
Garth
Garth!
Here the negative energy is the gravitational energy! The zero-energy universe hypothesis states that the total amount of energy in the universe is exactly zero. The positive energy of the matter is exactly balanced by the negative energy of the gravitational field.
If in an expansive Universe relativistic and quantum-mechanical properties are complementary, permanent constant maximum possible increase of negative energy of gravitational field must arise and simultaneously, permanent constant maximum possible increase of positive energy of the matter must occur, which compensate each other; hence, total energy of the Universe is equal to zero. Therefore, the expanding Universe must be non-decelerative and non-accelerative, i.e., during the whole expansive evolution phase, it must expand by constant maximum possible velocity v = c. So the universe expands linearly.
petergreen said:
Garth!
The zero-energy universe (depending on how you measure energy) is the flat universe.
The expansion rate is determined by the FRW equation in which curvature effects and expansion rates are convoluted. You have to solve the equations carefully and use the equation of state to separate out the two effects. It is possible to balance the eos using a certain amount of cosmological constant, (which I take to be a form of DE) but you then have to show that that model is observationally concordant. It here that Chalnoth and I disagree.
Garth
To be pedantic, it's a closed universe.
Disagree how now? Because it sounds to me like you're saying I don't think the correct model should be chosen by the data. What I do say is that I sincerely doubt the coasting model can explain cosmological perturbations we see in the CMB. Crucially, early-on, cosmic strings were thought to be a potential source of cosmological perturbations. Cosmic strings have an equation of state of [itex]w=-1/3[/itex], and would produce a coasting universe. Except the pattern of perturbations predicted by cosmic string models was completely and utterly different from the pattern predicted in inflationary models, and observations demonstrated that it was the inflationary models that fit the data.
There still may be some cosmic strings, but they don't make up a significant fraction of the energy density of the universe.
Chalnoth said:
And the main discrepancy between the coasting universe and ΛCDM is likely to be found in the power spectrum, which is not shown in the above paper.
But there are others who might disagree.
Observational Constraints of a Matter-Antimatter Symmetric Milne Universe
The main point we make in this article is that in spite of a significantly different evolution, the recombination history of a linearly coasting cosmology can be expected to give the location of the primary acoustic peaks in the same range of angles as that given in Standard Cosmology.
Garth
  • · Replies 27 ·
