Comparing Helium & Air Plasma in a Science Fair Experiment
The forum discussion centers on a science fair experiment comparing the plasma produced by air and helium in a microwave. Methodology A involved using air, while Methodology B utilized helium, with notable differences in ionization time and plasma behavior. Helium plasma ionized in 2 seconds, contrasting with the 3 seconds for air plasma, and exhibited distinct visual characteristics when influenced by an electromagnet. The discussion highlights the importance of understanding gas properties and the potential misinterpretation of observed phenomena as plasma.
  • Understanding of plasma physics and ionization processes
  • Familiarity with microwave oven operation and safety
  • Knowledge of gas properties, specifically helium and air
  • Basic experimental design and methodology
  • Research the properties of plasma and ionization in different gases
  • Study the effects of electromagnetic fields on ionized gases
  • Learn about the thermal properties of helium versus air
  • Investigate the limitations of microwave ovens in producing plasma
Students conducting science experiments, educators teaching physics concepts, and researchers interested in plasma behavior and gas properties.
Sciencekid
After a science fair experiment we have measured the similarities and differences of plasma created by air and helium. Our methodology is as follows.
Methodology A(air):
1. Light a match and place it on a small raised surface inside a microwave
2. Cover the match with a glass bowl/beaker, leaving a slight gap so air can ventilate the match.
3. Close the microwave door and turn it on for 15-20 seconds
4. Place electromagnet directly outside the microwave door
microwave door
Methodology B(helium):
2. Fill a glass bowl/beaker with Helium, upside down so it doesn’t escape (because helium is lighter than air).
3. Cover the match with the bowl/beaker, leaving a slight gap so air can ventilate the match.
4. Close the microwave door and turn it on for 15-20 seconds
5. Place electromagnet directly outside the microwave door
The helium reacted differently in the following ways: The helium plasma only took 2 seconds to ionize, whereas the air plasma took 3. Also the colour was slightly different in the two experiments. Perhaps the biggest difference was how when the electromagnet was introduced the air plasma took the shape of a small ball near the top of the beaker, while the helium plasma shook violently and eventually turned into an ionized flame. I was wondering why this happened and the science behind it.
Thanks in advance; Harry
This is a domestic microwave oven right?
With a turntable?
Something like this:
How many repeats of each experiment did you do?
Did you do the experiment without switching the microwave on?
Did you do the experiment without lighting the match, but the microwave is on?
(i.e. what is the role of each part of the experiment?)
I take it the match went out during the experiment - did you wait for the match to go out before turning the microwave on?
Note: in one you have a mix of air and helium, in the other you just have air.
After the match is lit, you can add the burning products from the match - these include carbon, sulfur, and phosphor compounds.
You have vibrations from the oven machinery, and uneven air-flow into and out of the container.
So there are quite a lot of variables to consider.
The main difference you observed concerned the stability of the glow - which will be due to the different mass and thermal properties of the gasses.
Note: microwave ovens do not have enough energy to ionize helium to a plasma.
From what I gather, it is unlikely that the glow you see is from a plasma and more likely from normal hot gas - maybe the phosphor from the match is florescing? Need to check some more.
http://hyperphysics.phy-astr.gsu.edu/hbase/waves/mwoven.html
  • · Replies 19 ·
  • · Replies 39 ·
16K
  • · Replies 0 ·
