10,000 Toothpick Model of a Bridge What Do You Think?
  • Thread starter Thread starter The Maker
    Bridge Model
The discussion centers around a bridge model constructed from 10,000 toothpicks, weighing 1306.15 grams and spanning 1.16 meters. Initially, a 1,000 toothpick bridge was built in 8th grade, which held 54 pounds before breaking. The current model, designed to hold a weight of 70 pounds, successfully supported the creator's sister without failure. The construction process involved innovative techniques such as using a bent ruler to create arcs and opting for wood glue for enhanced stability.
  • Understanding of basic engineering principles
  • Familiarity with structural design concepts
  • Knowledge of materials science, specifically adhesive properties
  • Experience with project planning and execution
  • Research structural integrity testing methods for model bridges
  • Explore advanced techniques in model building using alternative materials
  • Learn about the principles of load distribution in engineering
  • Investigate the use of CAD software for designing complex structures
This discussion is beneficial for engineering students, hobbyists in model building, educators in STEM fields, and anyone interested in practical applications of structural design principles.
The Maker
I hope that you enjoy my new video! Here is the description:
This is "10,000 Toothpick Model of a Bridge"
Specs
Weight: 1306.15 g
Height: 0.149 m
Length: 1.38 m
Span: 1.16 m
Width Of Foot: 0.195 m
Width Of Roadbed: 0.0615 mI built it in the 8th grade. A project in math class was to build a 1,000 toothpick bridge over a one foot span. My group's bridge held 54 pounds before breaking. The current bridge was planned to span to span 5ft. It fell a little short, but the actual span can be found above in the specs. I had my little sister, who was 70 pounds at the time, stand on the bridge, and it held her weight. She was 70 pounds. I do not want to test it any further! I do not care if it could hold a car and then break, I do not want a broken bridge. It took me about 2 months to complete it (December 2014 - January 2015). The original arc shape was the hardest to get right. I thought about making a huge compass, but that was impractical. I decided to bend a ruler and trace to the formed arc. This turned out to be a very elegant solution. I made toothpick squares and laid them out on the arc on graph paper. From there I built it layer by layer. It slowly formed a solid triangle. I used wood glue instead of hot glue in this project. This was a very good choice.
Very impressive ! :) :)
Very cool!
DennisN said:
Very cool!
Thank you both!
