5 Light-Year long stick question
  • Level: Undergrad
  • Thread starter Thread starter RCulling
68 replies · 89K views
JesseM said:
But like I said before, I'm assuming that we have some complete set of facts about the conditions at every local point in the spacetime, as would be true in the computer simulation example where the computer generates entire histories. There can't be a contradiction in such a complete set of facts.
I was talking about the method of proof by contradiction, and it can't be dismissed by saying that you are talking about a scenario without contradictions. It's certainly possible to make assumptions about matter that do lead to contradictions, and those contradictions would then prove the assumptions false.
JesseM said:
I disagree.
I probably didn't express myself very clearly, since the things you said right after "I disagree" are all things I agree with. I meant e.g. that if the laws that we think describe the behavior of matter say that it's always possible for a computer hooked up to a transmitter to send "1", and "global consistency" says that it isn't, then the laws we started with were inconsistent to begin with! (Does the "principle" really add anything here? I don't think so. An inconsistent set of statements wouldn't be considered a theory, so we don't need a "principle" to eliminate it for us, at least not if we have a definition of "theory" that makes sense).
Let me be more specific. Maxwell's equations are consistent, but they can't tell us if a computer+transmitter is able to send a specific tachyonic message, because they don't say anything about tachyons. So we would need a theory of matter (in this context I consider all fields and particles to be "matter") in Minkowski spacetime that includes both electromagnetic fields and tachyons. If we think we have found such a theory, and we find that it says that the computer and transmitter can always be built and always do what they're programmed to do, then the conclusion must be that we were wrong to think that we had a consistent theory (since the axioms of the "theory" imply the contradiction I described in the other thread), and we would have to start looking for another one.
So when we consider the question "Are tachyons consistent with SR?", we need to be a lot more specific. Some candidate "theories" that seem like they might be an accurate description of tachyons and their interactions with normal matter will lead to contradictions, and some might not. The ones that do can of course be ruled out. The simplest theories (in particular the one that treats tachyons as classical particles that just happen to have spacelike world lines) do lead to contradictions, and they can't be saved by some "consistency principle".
JesseM said:
Did you consider my computer simulation argument carefully?
I've read your arguments, but they are really just addressing aspects of this global consistency thing that I don't have a problem with.
JesseM said:
it could be true that by self-consistency, the fact that I received a 1 in the past means that the sender at a later time is constrained so he can't send a 0 back in time, even if he knows I got a 1 and wants to create a contradiction,
I'm still not buying that a universe where every sender chooses to murder his children (or gets hit by a meteor) instead of sending the message can be anything like ours. I don't have a proof that it isn't (at least not yet), but I expect that one can be found.
There is however a (seemingly) less crazy scenario that I might be able to accept. Suppose that the (quantum) theory that describes tachyons and their interactions with normal matter predicts that executing the "send" command on the computer+transmitter will generate a tachyon pulse with some probability P<1 that goes to zero as the entire scenario "goes to a contradiction" in some sense. That sounds extremely weird, but not as weird as the meteor/murder option. I can't really decide if I consider this a reasonable possibility yet, or even if it really is less weird than "meteor/murder". I would at least have to think about what that "limit" really means before I can decide.
There's also the possibility that I suggested in the other thread: That the time it takes to emit/detect a tachyon grows faster than linearly as a function of the distance between the emitter and the detector.
I would say that neither of these "loopholes" in the original argument relies on a "consistency principle".
dx said:
Not sure what you guys are talking about
We're talking about whether a "consistency principle" can be a reason to think that tachyons might exist. I still don't see how such a principle is actually saying something that isn't already a part of any reasonable definition of "theory".
I'm talking about considering what would happen if you consider a very large ensemble (perhaps infinite) of "random histories" where each history consists of a set of facts about each local point in spacetime where the facts are assigned completely randomly, with no regard for any laws of physics whatsoever (aside from laws limiting what is possible at a single point, like laws which give allowable particle masses); then if we define "laws of physics" in terms of constraints on the relation between local facts at one point and local facts at other nearby points (or perhaps arbitrarily distant points if we allow FTL), then we can simply go through every history in the ensemble and throw out all the ones where the laws of physics don't hold at every point, then what we should be left with is a set of histories where the laws of physics do hold at every point.
Do you think there is something incoherent or impossible about the first part of this, considering a huge ensemble of "random histories"? If not, then by definition since each history gives only a single set of facts about what occurs at every point, then each history in the ensemble must be "noncontradictory", even if it shows complete disregard for any laws of physics. If you were arguing somehow that it would be impossible to find a single member of this ensemble that obeyed the laws of physics at every point (or that the laws of physics cannot be stated in a local form so that the notion of 'checking every point' in a history doesn't make sense) in the case where the laws of physics allowed for time travel, I suppose I could understand the argument even if I disagreed with it, but I don't understand how your claim of a "proof by contradiction" is supposed to apply to my argument, where by definition each member of the original random ensemble is a single noncontradictory history.
Fredrik said:
I probably didn't express myself very clearly, since the things you said right after "I disagree" are all things I agree with. I meant e.g. that if the laws that we think describe the behavior of matter say that it's always possible for a computer hooked up to a transmitter to send "1" and "global consistency" says that it isn't, then the laws we started with were inconsistent to begin with!
I still think you are failing to distinguish between conditional and unconditional possibilities. Even in a non-time-travel universe it's not "always possible" for a computer hooked up to a transmitter to send a 1 if we take into account conditions in the past or future light cone of the event of the computer sending a signal--for example if the laws of physics are deterministic then detailed knowledge of the transmitter's microstate in the past light cone may be sufficient to guarantee that the computer is going to send a 0 (even if its macrostate immediately before sending a signal is the same macrostate that has been observed for other transmitters that sent a 1), and likewise if we imagine an observer viewing the 4D spacetime from "outside" who can examine conditions in the future light cone before examining conditions when the signal was sent, that observer can see that if the future light cone includes the receiver getting a 0, then it's not possible for the transmitter to have sent a 1. Same in a universe with time travel, if you think in terms of unconditional probabilities then it is indeed "possible" for a transmitter of this type to send a 1, but if you already know some more facts about other regions of same history then the conditional probability of it sending a 1 given these other facts may be zero.
Again, if our laws of physics give some set of possibilities for local conditions at each point in spacetime (or at each cell in a discrete cellular automata or something similar), then we can simply consider the ensemble of all possible ways of assigning local conditions to each point, the vast majority of which will be completely random and won't obey any laws, but which will at least each be noncontradictory. Then if we state "laws" in terms of mutual constraints on the relationships between conditions at different points (possibly differential equations dealing with infinitesimally nearby points) we can consider the question of whether there will be at least some members of the ensemble of random histories which obey these laws at each point, and since every member of the original ensemble was a noncontradictory history, the subset of law-obeying histories would each be noncontradictory too. Perhaps you are saying that your "proof by contradiction" is supposed to prove that there would be zero self-consistent histories of this type, but if not I don't understand how your argument is supposed to be a counter to mine. And if that is what your argument is supposed to prove, it seems much too handwavey, as it deals with complicated macroscopic devices as opposed to microphysics--there's no way we could actually build a device that would infallibly send a 0 when it received a 1, there's always some possibility of error or interference from external influences.
But remember, the whole point of the rule is that we generate a huge number of universes where anything can happen and then throw out the ones that don't meet the correct conditions. Some of these random histories might include sub-regions that obey the correct local laws and which include things like an experimenter getting a "1" from his partner outside the region (with memories that the partner was supposed to just transmit the same digit back by tachyonic signal) and later sending a "0" to his partner, but most random histories like this would get thrown out because the local laws failed to be obeyed at points outside the region (for example, if local laws were also obeyed in the region of the partner, and that region included the event of the partner getting a "0" and sending back a "0", then there would have to be some local along the points in spacetime that the tachyon's worldline passed through). By definition, the only ones that remain after the process of throwing out all those that are noncontradictory (because all the 'random histories' generated before any were thrown out were at least noncontradictory) and which have no discontinuities or other breakdowns in the local laws. Since this is just a tiny subset, any given region of spacetime where someone is trying to create a contradiction may be a lot more likely to contain "weird events" then if we consider the larger subset of random histories where just that region (but not necessarily the rest of the universe outside of it) obeyed the correct local laws throughout and contained someone trying to create a contradiction, but that's because we had to throw out all the ones where various coincidences didn't prevent someone from acting in a way that could be part of a single self-consistent global history that obeyed the correct laws everywhere.
Another analogy: suppose I show a series of videos of people approaching unlocked doors with intent to open them, pausing each video before they actually reach the door. You'd expect that most of them will reach the door and succeed in opening it, right? But suppose I tell you I am actually an immortal alien with a fetish for seeing humans fail to open doors, so I have been using tiny hidden cameras to make movies of every human that ever approached an unlocked door with intent to open it throughout history, and then I simply throw out all the boring ones where they succeed and keep the interesting ones where they don't for my collection. Then if you believe my story is correct, you naturally know that in all of the videos the person will fail to open it--there might be all sorts of weird "coincidental" reasons, for example some might show the person hearing someone in the opposite direction calling their name before reaching the door, some might show them slipping on the floor and being knocked unconscious, some might show them simply stopping and changing their mind for some reason, etc. Taken together this set of videos would seem extremely coincidental, but if we know it's just a specially-selected subset of a much larger set of videos where the door-openings were usually successful, we needn't find these "coincidences" too surprising!
What do you mean by "reason to think that tachyons might exist"? I certainly don't think tachyons are likely to exist in the real world, or that a "consistency principle" increases the likelihood that they exist in the real world. It just shows that there doesn't need to be any logical contradiction in the notion of tachyons (or any other form of causality violation) that would allow us to rule them out a priori. I'm just saying that it's logically possible that that 1) the local laws of physics are Lorentz-invariant and allow tachyons, and 2) out of all possible "histories" which assign local states to each point in spacetime, it's logically possible that some small subset would obey the local laws specified by 1 at every single point. If 1 and 2 are correct, then any member of the subset described by 2 would necessarily be one that is globally self-consistent, so any attempts to create "time travel paradoxes" would fail in this subset.
dx said:
Not sure what you guys are talking about since I didn't read the thread but..
Well, if you want to understand this discussion between me and Fredrik it isn't actually necessary to read the whole thread, you can just start with Fredrik's post #37 and read subsequent posts by Fredrik and me after it.
Back to (almost) the initial topic of this thread. Early on, someone proposed that hitting a 5 meter rod would push 'instantly' on the other end. This was roundly and validly criticized. It occurred to me that modern techniques should readily measure the small, finite time for the far end to respond. The link below describes a test method to determine the tensile strength of rigid ceramic rods of laboratory size precisely by measuring the propagation delay between hitting one end at arrival at the other. Sometimes this sort of concrete (or ceramic) response is better than a lot of theory.
http://www.mater.upm.es/fgalvez/PDF/Dymat00-Tech.pdf
I don't. That's why I said that your analogies are only addressing the things I don't have a problem with.
I would describe the things you just said (in this quote) a bit differently. Whatever theory we have for tachyons and their interactions, it includes some sort of "equation of motion". Let's say that the theory is a classical field theory. Then the solution is a field. The algorithm you're describing is simply generating fields randomly, and then checking if they solve the equation. A field solves the equation of motion if and only if, for each finite region of spacetime, the restriction of the field to that region is the solution to a boundary value problem for that region. (The boundary value problem is defined by the same equation and by the values of the field on the boundary). This is all fine, but it doesn't seem to have anything to do with some "principle of consistency".
Agreed. When the theory is a field theory, a random "history" is just a field that may or may not solve the field equation.
Exactly...so why did you use these arguments in response to something I said about proofs by contradiction? (Rhetorical question). We have clearly been talking past each other for a while.
I was just showing you an example of how it's possible to make assumptions that lead to a contradiction. The assumption that the computer and tachyon transmitter can always do what they're supposed to do implies that there are no restrictions on the initial state.
The issue isn't whether tachyons can be ruled out, but whether the consistency principle prevents them from being ruled out. I still say that the principle adds absolutely nothing. Some sets of axioms for candidate theories of tachyons in Minkowski spacetime can be easily dismissed, as they are inconsistent (and wouldn't be if we just remove the tachyons), but that's really all we can say. This doesn't involve the principle in any way. The principle doesn't tell us anything (as far as I can tell) about which axioms define valid theories and which ones don't. It doesn't seem to say anything about anything.
How does it do that? Any theory of matter and interactions in Minkowski spacetime (or any other spacetime) is consistent by definition of "theory", so we don't need a "principle" to tell us that a theory of tachyons is consistent. The principle also doesn't invalidate any proof that shows that a given set of axioms is inconsistent. So what exactly does it do?
Edit: I appreciate the efforts you have made trying to explain your views to me, but I don't think more analogies would help. (Just trying to save you some time :smile:)
What do you mean? Do you agree that if the local laws are such that some valid solutions include causality violations (whether this is because the local laws involve time travel or because the local laws include the Einstein field equations along with matter fields that violate the energy conditions that need to be violated in order for a GR solution to allow for the creation of timelike curves), then if we generate a vast (perhaps infinite) set of "random spacetimes" with all the fields and curvature at each point set at random, then throw out all the ones that include any violations of the local laws leaving only spacetimes that respect them at every point, then these remaining spacetimes will all obey the principle of self-consistency? As the authors of the paper on the self-consistency principle said in the quote I brought up earlier, the "principle of consistency" is not a separate assumption from the idea that we live in a spacetime with a unique truth about the physical facts at each point and where the same local laws are respected in the neighborhood of each point, it's just a statement of one consequence of those assumptions for any situation involving causality violations. But you seemed to say that somehow the "principle of consistency" was actually inconsistent with the idea that the same local laws are respected at every point, in statements like this one from post #57:
Fredrik said:
This is what I can't accept. The properties of tachyons and their interactions are such that all scientists would choose to murder their children rather than change a 0 to a 1 in a computer program? If I use a telescope to look for meteors before I make the change, I will die in a terrorist attack instead? If I lock myself away where I'm safe from terrorists, I have a heart attack instead? If I make sure that I'm in perfect health...I guess we're back to ninja turtles.
What I just described doesn't sound anything at all like the universe we live in, and I also don't think it can be justified by a rule that says that the same "local laws" are obeyed in each region of spacetime. If these "local laws" say that I can build a device that sends instantaneous messages (in the device's rest frame), and the same thing can't be done in another region of spacetime, then I would say that the laws in that region are different from the laws in the first region, or alternatively, that the laws are the same everywhere, but different from what we previously thought that they were. I know the principle explicitly said the there won't be any new physics, but now I think it contradicts itself on that point.
So do you still think there is some contradiction? Obviously any theory involving tachyons would necessarily involve some new physics, but the principle was originally meant to apply in the GR case, so let's consider that one. If 1) we assume GR plus some local laws governing matter fields, and these laws allow for the violation of energy conditions needed for CTCs, and they are also rich enough to allow for the existence of things like sentient observers and computers, and 2) we imagine generating the infinite set of all possible pseudo-Riemann manifolds with arbitrary curvatures and arbitrary values for the matter fields at each point, and 3) we throw out all the ones that don't respect the Einstein field equations and the local laws governing matter fields, then 4) do you agree it's very plausible that at least some of the remaining lawful spacetimes will include sentient observers who have access to time travel and at some point have a desire to "change history"? If you do agree with 4), then do you agree that by just virtue of how this set of lawful spacetimes was generated, in every single member of the set all sentient observers must fail in attempts to change history, whether for simple reasons like changing their minds or very weird coincidences like dying in a terrorist attack or having a heart attack? (no need to answer this question if you don't agree with 4, obviously!) And if you do agree with that last bit, then would you also agree that the conclusion of such consistent failures 'can be justified by a rule that says that the same "local laws" are obeyed in each region of spacetime'? Please give me clear answers to these questions, because I'm really having trouble understanding what you're arguing.
But I thought your earlier argument wasn't just that these assumptions lead to a contradiction, but that you think we actually have some very good reason to think these assumptions are valid, and thus that any universe in which events "conspired" to prevent people from creating paradoxes would be one wildly incompatible with facts we already know about the real universe. If so, I just don't see it--a universe with tachyons or wormhole time machines that sentient beings took a while to discover/create could well look a lot like ours until the time where some causality-violating device was actually built by them.
But like I said, isn't that exactly what the authors of the paper on self-consistency were saying in that quote too? The self-consistency principle is not any sort of additional law beyond just the requirement that the same local laws apply everywhere, if the local laws allow time travel then it seems to just be a logical consequence.
Like the quote said, it's just a statement of the fact that no new laws come into play in regions containing CTCs than in other regions (and in GR CTC-containing regions may be cleanly divided from regions where none can occur by Cauchy horizons), the same local laws apply everywhere. If you have no problem with this, I don't see why you object so strenuously to the idea that events would "conspire" to thwart attempts by time travelers to change history, do you think it's not an obvious logical consequence of the assumptions of "local laws allow for solutions with causality violations" + "local laws apply at every point"?
Do you there is an inconsistency in the idea of the local laws allowing for causality violations plus the ideas that the local laws apply at every point and that they allow for things like computers and sentient observers who formulate plans to change history?
A short summary in case someone else wants to join in: There's a standard argument that attempts to show that FTL messages are inconsistent with special relativity. (See this post). It shows that the following assumptions lead to a contradiction:
  • The assumptions of special relativity.
  • We can program a computer to send the same bit it received, and make sure that it actually sends it after a delay specified by the program.
  • We can program a computer to send the XOR ("opposite") of the bit it received, and make sure that it actually sends it after a delay specified by the program.
  • It's possible to build a device that sends a message that travels at speed v>c relative to the device, when it's instructed to do so by a computer.
The counterargument that was brought up by JesseM in this thread, and by Demystifier in another one, goes roughly like this: It's undeniable that those assumptions lead to a contradiction, but that doesn't rule out FTL messages. The time evolution of the state of the matter in the universe is described by a solution to an equation of motion of some theory. A solution is by definition a single-valued function, and it would (at least) take a multi-valued function to describe a "contradiction" (if it makes sense to try to describe contradictions at all), so there can't be a solution that describes an experiment where the components mentioned above work properly. There might be solutions where one component part is malfunctioning, solutions where the experimenter decides not to push the start button, solutions where the experimenter decides to push the start button but gets hit by a meteor that's been heading his way for a billion years just as he tries to push it, solutions where an intelligent species discovers a way to blow up their solar system the year before they would have discovered how to send FTL messages...but no solutions where this whole thought experiment is actually carried out.
The question is, is this "consistency principle" a valid counterargument to the standard argument against FTL messages? Is it a reason to say that there might exist a theory that allows FTL messages and is consistent with special relativity? I'm still not sure. Something about this argument just feels very wrong, but I still can't put my finger on it.
[/summary]
It's interesting to try this counterargument on a "proof" that Newtonian gravity is inconsistent with SR. Consider two rockets that are held at fixed positions in some inertial frame S. The rockets are attracted to each other gravitationally, but they're held in place by a thin string that just barely can handle the force. Any additional force, and the strings would break. At some event on the world line of rocket A, its engine is turned on. It breaks the string that's holding it, and it starts accelerating towards rocket B. As the distance in S between the rockets decreases, the gravitational force that A exerts on B increases, so B's string must break too. But when? Newton's law of gravity says that the effect will be felt "immediately", but that means something different in each inertial frame, and SR says that all these inertial frames are equivalent. So the theory of Newtonian gravity+SR makes infinitely many different predictions about at what event B's string breaks.
The counterargument would be that the equation of motion of matter can't have a solution that describes this scenario. There might be a solution that describes a scenario that starts out the same, but where rocket A never moves. So we can't rule out that Newtonian gravity is consistent with SR. This is what makes things interesting: While using the "consistency principle" counterargument to save Newtonian gravity, we ruled out motion instead. Newtonian gravity is consistent with SR, but only if massive particles are constrained not to move. This means that the theory that saves Newtonian gravity makes predictions that are contradicted by all experiments. So the counterargument is useless here, and really doesn't save Newtonian gravity.
I don't have a similar argument for FTL messages, but that doesn't mean that one can't be found. So while I agree that the counterargument has shown that things aren't quite as simple as they seem at first, I'm still not convinced that it can save FTL messages. I also think it's misleading to call this counterargument a "consistency principle", because it's really just a reminder of what a solution is.
