Does High Energy Electron Interaction Reveal Asymptotic Freedom in Quarks?
  • Context: Graduate
  • Thread starter Thread starter Manojg
The discussion centers on the phenomenon of asymptotic freedom in quarks, particularly in the context of deep inelastic scattering (DIS) involving high-energy electrons. Participants explain that quarks behave as free particles at short distances due to the decreasing strong interaction force, while electromagnetic interactions dominate during high-energy collisions. The analogy of bowling balls connected by springs illustrates how quarks remain bound yet appear free under certain conditions, emphasizing that at high energies, the interaction can be filtered to reveal the quarks' behavior.
  • Understanding of deep inelastic scattering (DIS)
  • Familiarity with electromagnetic interactions and virtual photons
  • Knowledge of quark confinement and asymptotic freedom
  • Basic principles of particle physics and scattering theory
  • Study the principles of deep inelastic scattering (DIS) in detail
  • Explore the concept of quark confinement and its implications
  • Research the role of virtual photons in particle interactions
  • Investigate the mathematical modeling of scattering patterns in particle physics
Particle physicists, researchers in quantum chromodynamics, and students studying the interactions of fundamental particles will benefit from this discussion.
Manojg
Hi,
I have a simple question related with asymptotic freedom.
Quarks behave as free particles at small distance (separation between the quarks is small) because strong interaction decrease with decrease in distance or increase in energy. So, one quark feels almost independent of other.
Now, in DIS where hadron is probed by high energy electron: basically virtual photon interact with quarks inside the hadron. The interaction is electromagnetic. At high energy or short distance the electromagnetic interaction is larger. There is no strong interaction with the projectile. Then, why electron sees the quarks as free? Quark-quark feel them self as free from each other.
Thanks.
The quarks can't separate because the stong force increases as they get further apart. When enough energy is put into force them apart, new quarks come into being, attached to the original quarks, leaving them still paired.
Yes, I know that. But my question is different. Interaction of virtual photon with quarks is electromagnetic, not strong. Then, why the electron in DIS (deep inelastic scattering) sees the quarks as free at high energy?
Electromagnetic scattering is well understood, so the effect can be filtered out of the results.
Imagine that you were in outerspace and 100 yards away was something that looked like a bowling ball, but someone told you it was actually three bowling balls connected together. Then you have an unlimited number of bowling balls to throw at the target, and a lot of patience.
Fairly quickly you determine that the bowling balls cannot be separated, the three of them are always connected (in my analogy this corresponds to the property of quark confinement that mathman was mentioning, although in my analogy I am ignoring the possibility of what happens when the flux tubes break).
Now you want to determine the nature of the bonds that connect the bowling balls. Basically you expect them to be connected by tight springs. Then you do a calculation of the scattering pattern you expect to occur as a function of the spring constant. After doing the experiment it turns out that the spring constant is zero, and so in fact the springs have some slack in them, asymptotic freedom.
Imagine two particles bound with a spring. They oscillate around an equilibrium position r_0 but most of the time they spend at extreme (turning) points where their velocity is the smallest. So most of the time they feel themselves interacting rather than free.
If you push (or pull) one of them very slowly, you will feel the total mass - the system is accelerated as a whole on average.
If you push one of them suddenly, during delta_t << oscillation period AND the perturbation of the spring propagates with finite velocity from the pushed particle to the second one (delta_t<<r_0/c), then you will "feel" only the pushed particle whatever oscillation phase is.
So for a very fast projectile, the quarks may look free.
Bob.
  • · Replies 35 ·
9K
  • · Replies 0 ·
