yoelhalb
- 69
- 0
According to special relativity acceleration is an absolute motion, so according to what is it moving?
Better state: According to relativity, the magnitude of proper acceleration is Lorentz invariant. That doesn't mean the same as saying acceleration is absolute motion.yoelhalb said:According to special relativity acceleration is an absolute motion
That depends on what spacetime coordinate system he chooses to use--there is no physical reason that any given observer must use one coordinate system or another, although the usual convention is that each observer uses a coordinate where his coordinate position doesn't change with coordinate time (a coordinate system where he is 'at rest'). For a non-inertial observer there would be many different possible non-inertial coordinate systems where this could be true, which would have different judgments about the velocities of distant objects. And while his own coordinate acceleration would be zero in such a coordinate system, that wouldn't change the fact that he feels G-forces, which would be explained in terms of some sort of "pseudo-gravitational force" in this system (similar to a fictitious force in Newtonian physics), see the equivalence principle analysis from the twin paradox FAQ for details on this.yoelhalb said:My question is what does he think? what is by him considered rest and according to what is he moving?
Yes, but he would know the coordinate system where he remains at rest is not an inertial frame, so the usual equations of SR such as the time dilation equation won't apply in this frame (though at any single instant on his worldline there will be some inertial frame where he is instantaneously at rest).yoelhalb said:So in other words one who accelerates might claim that he is at rest
JesseM said:That depends on what spacetime coordinate system he chooses to use--there is no physical reason that any given observer must use one coordinate system or another, although the usual convention is that each observer uses a coordinate where his coordinate position doesn't change with coordinate time (a coordinate system where he is 'at rest'). For a non-inertial observer there would be many different possible non-inertial coordinate systems where this could be true, which would have different judgments about the velocities of distant objects. And while his own coordinate acceleration would be zero in such a coordinate system, that wouldn't change the fact that he feels G-forces, which would be explained in terms of some sort of "pseudo-gravitational force" in this system (similar to a fictitious force in Newtonian physics), see the equivalence principle analysis from the twin paradox FAQ for details on this.
You are now asking about General Relativity instead of your original question which was limited to Special Relativity and which I tried to answer for you in a way I thought you could and would understand. Do you understand my answer to your original question?yoelhalb said:If so then why does Galileo's ship which is clearly on Earth and feels gravity, how can all physics law's apply to him?
I don't think any of my introductory SR texts goes into much detail on the issue of accelerating frames, but I often find one can find interesting-looking textbooks by entering keywords into google books...with keywords "relativity" + "accelerating" + "frame" I found http://books.google.com/books?id=LyVxtGv1RwEC&lpg=PA83&dq=relativity%20accelerating%20frame&pg=PA81#v=onepage&q=relativity%20accelerating%20frame&f=false , Dynamics and Relativity, and Explorations in mathematical physics: the concepts behind an elegant language (which has a very nice discussion of the derivation of Rindler coordinates, the most common type of accelerated frame, on p. 240), for example.yoelhalb said:Do you have a good source that explains special relativity in such a level of detail?
Just by analyzing things from the perspective of the inertial frame where A was at rest as B and C moved away. If you choose to use a non-inertial frame where C is at rest, then in this frame A was not at rest.yoelhalb said:Here is a similar question.
Imagine A,B,C are at one position, then A and B starts to move away with uniform motion.
C moves with acceleration starting with a lower speed and eventually catching up with A.
How can we claim that A was at rest?
JesseM said:Just by analyzing things from the perspective of the inertial frame where A was at rest as B and C moved away. If you choose to use a non-inertial frame where C is at rest, then in this frame A was not at rest.
So how will C ever meet him if he moved away?JesseM said:Just by analyzing things from the perspective of the inertial frame where A was at rest as B and C moved away. If you choose to use a non-inertial frame where C is at rest, then in this frame A was not at rest.
Are you assuming B and A both go in opposite directions at the same speed in the frame where all four were originally at rest next to each other? Then C accelerates in the direction of A, D accelerates in the same way but in the direction of B? In this case, yes, B should catch up with B and C should catch up with A.yoelhalb said:Let's put it differently.
the same example again but n ow together with all of them also started D in the direction of B with the same acceleration of C in A's direction will he catch up with B?
JesseM said:Because in a non-inertial frame of C, A would move away but then move back towards C.
Do you mean each is moving at 100 mph in the other's rest frame, or do you mean that in the frame where both were originally at rest (the frame of the ocean) they are both moving at 100 mph in opposite directions? It doesn't really matter since it will only affect the specific numbers and not the overall analysis, so I'll assume the second one for now...yoelhalb said:Let m e explain the whole question again.
ABC are at the same position one next to the other.
Now A and B are moving apart with a constant speed of 100 mph (imagine ships in the water).
If C accelerates in the direction of A, he'll be closer to A than to B, although the distance from A to C is still increasing rather than decreasing (it's just not as increasing as fast as the distance from B to C)yoelhalb said:Also according to C in the same second A and B took apart, he started accelrating with a speed of 1 mph in the direction of A's travel.
(actually the question starts here will he be a mile close to A or to B?).
If C keeps accelerating by 1 mph every hour in the ocean frame, then eventually C's speed will exceed A's speed of 100 mph in this frame. At that point, in A's inertial rest frame, C should start moving back towards A.yoelhalb said:A initially sees this as C moving away from him with 99 mph.
The next hour C speeds up with another 1 mph to a total of 2 mph, and so on till he meets A.
According to A how can this happen? C initially moved away form him and never moved back.
(As you can see there are actually 2 questions)
Again ABC are togheter.JesseM said:If C accelerates in the direction of A, he'll be closer to A than to B, although the distance from A to C is still increasing rather than decreasing (it's just not as increasing as fast as the distance from B to C)
