Absolutely central elastic collision (or translate lying)
14 replies · 2K views
Gustavs1337
2 balls, their size is the same but mass is different, they are going towards a collision. I do not know what is the word for it in english but its like this m1= 1,2m2. Speed of the balls are v1=12m/s and v2= 15m/s.Calculate the speed of each ball after absolutely central elastic collision.
p=mv
p=p,
I could not even think of a solution since I missed out some classes.
Doc Al said:
What's conserved in an elastic collision?
BvU said:
I don't see the connection between the relevant equations and the attempt at solution ?
yes all i can write is p1= 1,2m2 x 12 = 14,4m2 but i can't get past this part, the p= p, is just a reminder for me. And i think that its kinetic energy that's being conserved.
It should remind you that momentum is conserved.
Right.
So combine those two conservation laws.
Its going to be hard since english is not my born language. so i couldn't figure it out so i looked on the internet and this is what i got K = 1/2m(p/m)2= p2/2m
That's just expressing the kinetic energy in terms of momentum instead of velocity. That won't help you.
You need to write equations for:
  • conservation of energy
  • conservation of momentum
I assume you have a textbook. I suspect it gives examples of this sort of collision.
As I said before I missed out on some classes, they were doing the similar but easier tasks and I did not ask for their notes so that is my fault. Conservation of momentum is m1xdv1=-m2xdv2 as it says. And Energy i don't know that, or maybe its because of the differences in language.
There are four velocities involved: The initial and final velocities of each object.
I don't think language has much to do with it. :smile:
Again, check your textbook.
And read this: Wiki: Elastic Collisions in one dimension
so you mean i should do it like this ?
or this
? And about that energy, i could not find anything but Ek= Ek'. There is also this ∑p = constant but i doubt it, also Ek= mv2/2 but also i doubt that. Only equation that i think would be right is the first one. :/. I have something to add
m1v1 + m2v2 =[m1+m2]v3 mayb e this
Both conservation equations are given in that Wiki link. They even solve them for you!
so basically
this is the momentum equation as it says and this
is energy equation.
and i get
by combining them ?
You want me to put numbers in those equations or understand how i got the combinations, i have a hard time understanding what comes next.
Yes, just plug the numbers in.
By the way, the correct translation is probably "head-on elastic collision", i.e. the mass centres, direction of relative motion and point of impact are all in a straight line.
