Why Does Removing CO2 Make a NaHCO3 Solution More Basic?
  • Thread starter Thread starter Puchinita5
The discussion centers on the chemical behavior of sodium bicarbonate (NaHCO3) in water and the impact of carbon dioxide (CO2) release on solution pH. When NaHCO3 dissolves, it produces bicarbonate ions (HCO3-) that can convert to carbonate ions (CO3^2-) and carbonic acid (H2CO3). The removal of CO2 from the solution decreases the concentration of H2CO3, leading to a more basic solution as the acid concentration diminishes, thereby increasing the pH.
  • Understanding of acid-base chemistry, specifically the bicarbonate buffering system.
  • Familiarity with chemical equilibrium and Le Chatelier's principle.
  • Knowledge of pH scale and its relation to acid and base concentrations.
  • Basic understanding of chemical reactions involving NaHCO3 and CO2.
  • Study the bicarbonate buffering system in detail, focusing on its role in biological systems.
  • Learn about Le Chatelier's principle and its applications in chemical equilibria.
  • Explore the effects of CO2 on ocean acidification and its implications for marine life.
  • Investigate the role of NaHCO3 in various industrial and laboratory applications.
Chemistry students, educators, and anyone interested in acid-base reactions and their practical applications in environmental science and biochemistry.
Puchinita5
The question was:
When you add solid NaHCO3 to water the solution becomes basic. As you stir the mixture to dissolve all the NaHCO3 (or as the solution sits) bubbles of CO2 are released. This occures because HCO3- ions react with one another to a small extent according to:
2HCO3- ---> CO3^2- + H2CO3
H2CO3 <----> H20 + CO2
The conjugate acid/base of HCO3- are H2CO3 and CO3^2- respectively. When CO2 is lost from the solution, the concentration of _____ (acid/base) decreases. Therefore, the more CO2 that is lost, the ____(more/less) basic the solution becomes.
Looking at the second equation, I want to say that if CO2 decreases, this would drive the reaction to the right to compensate for the loss, decreasing H2CO3, the acid. Therfore, the concentration of acid decreases and the solution becomes more basic. However, other students in my class for the most part disagreed with me, and I can't seem to find out what is the right answer. If I am right, can someone let me know? And if I am wrong, can someone explain to me why??
Thank you!
You are right - when CO2 escapes the solution it is technically equivalent to removing part of the acid. pH must go up.
Change in amount of acid always means change in pH, and this change always go in the logical direction - more acid, lower pH, less acid, higher pH. When you start with NaOH solution exposed to the air quite the opposite happens - such solution absorbs CO2 from the air. That means adding acid, so pH goes down.
methods
18K
