Actual number of stars in the Milky Way
  • Context: Undergrad
  • Thread starter Thread starter Stickman76
    Milky way Stars
The discussion revolves around the varying estimates of the number of stars in the Milky Way Galaxy, specifically questioning whether the actual number is closer to 200 billion or 400 billion. Participants explore the methods used to estimate these numbers, including the challenges posed by observational limitations and the characteristics of stars within the galaxy.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants note the wide range of estimates for the number of stars in the Milky Way, from 200 billion to 400 billion, and question which figure is more accurate.
  • Methods for estimating star counts are discussed, with references to the James Webb Space Telescope (JWST) as a significant tool, though other methods are implied to exist.
  • One participant highlights that about 85% of the Milky Way is obscured by dust, complicating the counting of stars, particularly red dwarfs, which are dim and difficult to observe.
  • Another participant suggests that estimates are based on surveying observable areas and extrapolating based on the known size of the galaxy, while acknowledging the potential for significant discrepancies in estimates.
  • Concerns are raised about the assumption that the ratio of red dwarfs to brighter stars remains consistent throughout the galaxy, particularly in less visible regions.
Participants express uncertainty regarding the actual number of stars and the methods used to estimate them. There is no consensus on whether the number is closer to 200 billion or 400 billion, and multiple competing views on the estimation methods and challenges remain evident.
Limitations in observational data due to dust and the geometry of the galaxy are noted, as well as the qualitative differences in star populations in different regions of the Milky Way.
Stickman76
I hear wild varying estimates of how many stars there are in the Milky Way Galaxy, from 200 billion to 400 billion. Is the number closer to 200 billion or closer to 400 billion? What methods are being employed (other than GAIA) in order to count them?
Astronomy news on Phys.org
Stickman76 said:
What methods are being employed?
https://www.jwst.nasa.gov/
While it's not the only one, it's a pretty big deal
rootone, thank you! I am familiar with JWST as well. Can't wait for it to get into space and start doing science. Do you know how the number of stars has been estimated to date? And why the large discrepancy between estimates I mentioned in my OP? Thanks!
About 85% of the Milky Way is invisible to us because of dust (and to a lesser extent, geometry). Most stars are red dwarfs, which are extremely dim. Combine the two, and it's hard to count what you don't see.
Especially because the invisible part is qualitatively different. We may assume that the ratio of red dwarfs to bright stars is the same on the far side of Milky Way disc as it is on the near side, but most of the stars are in the inner Milky Way, which is also hid, and we have no reason to assume the ratio of red dwarfs to bright stars should be the same there.
Snorkak, thank you for the additional input. So then it seems as though our estimates of how many stars there are in the galaxy is based on a survey of a given observable area of the galaxy and an approximation of the stars in that area that is then multiplied by the known estimated size of the galaxy, or similar technique. I suppose the estimation takes into account that there are more stars toward the center and fewer toward the outer edges, however it seems as though there is a large discrepancy between the high and low estimates. 200 billion - 400 billion is a 100% increase. This is a hard problem as are many in astronomy, however I am pursuing a career in said field and am very curious about the Cosmos so I will continue to ask questions. Thanks again to all who have chimed in on this topic.
  • · Replies 87 ·
10K
  • · Replies 30 ·
  • · Replies 29 ·
  • · Replies 19 ·
  • · Replies 29 ·
9K
