Alternative Methods to Die Casting :
  • Thread starter Thread starter ronvieky
    Casting
The discussion focuses on alternative fabrication methods for creating small tubular components from Copper-Beryllium or Copper-Nickel alloys, specifically with dimensions of R1 = 5mm, R2 = 6.5mm, L = 40mm, and Rc = 3mm. Die casting is deemed too expensive for the required quantity of 20 pieces, prompting suggestions for more cost-effective methods. Recommendations include using a lathe and reaming, consulting a machine shop, and considering lost wax casting or rapid casting techniques for precision and budget-friendly solutions.
  • Understanding of machining processes such as lathe work and reaming
  • Familiarity with casting techniques, specifically lost wax casting
  • Knowledge of brazing methods for metal joining
  • Basic principles of heat transfer applications in metal components
  • Research lost wax casting techniques for small precision parts
  • Explore rapid casting services for low-volume production
  • Learn about machining processes specific to Copper alloys
  • Investigate the properties and applications of Copper-Beryllium and Copper-Nickel alloys
Engineers, machinists, and product designers involved in the fabrication of precision metal components, particularly those working with Copper alloys for heat transfer applications.
ronvieky
Anyone knows of any alternative methods ot fabricate a Copper-Berrilium / or Copper-Nickel / alloy into a small tubular form (Custom design)...
I need to Mold a Copper Alloy with the following dimensions : Precision required.
http://www.fileden.com/files/2008/4/23/1880222/Copper%20Tube%20Fabrication.JPG
R1 = 5mm
R2 = 6.5mm
L = 40mm
Rc = 3mm
(tip of this part is conical, and Closed, hence radius of this Hemisphere end Rc )
And that's it. But i need a maximum of 20 Pieces of this part. So i cannot go for Die-casting. It'l be way too expensive for me... Does anyone know of any other methods to fabricate this in Copper - or any of its alloys?
I need it for Heat-transfer applications, which may involve rapid heating and cooling of the part. What is the best way to do this? and the cheapest. cuz, i don't want high volume. only high precision.
Please suggest.
Thanks.
I was going to suggest a lathe, and reaming, but that's after mistaking your dimensions as cm. If you have access to a machine shop / good machinist you should probably talk to them and see if they might be able to help you. On the other hand, you'd probably be able to braze a hollow semisphere onto the pipe, but that might impact your intended use:
http://en.wikipedia.org/wiki/Brazing
If you can get it in bar stock you shouldn't have a problem machining it.
lost wax casting ?
cheap
good enuff for jewelry
Not sure but in the past, these guys have given us detailed help with lost wax / http://www.deangroup-int.co.uk/" queries. May be try giving them a call?
i have used rapid casting in the past and that is good for up to 50 off depending upon the tool. Quite a small part so shouldn't be too pricey. what's your budget?
10K
