Am I interpreting Einstein correctly?
  • Level: Graduate
  • Thread starter Thread starter bcrowell
    Einstein
39 replies · 8K views
Antiphon said:
Minor point regarding the energy/frequency business;
The energy of a classical EM wave does not depend on frequency, only amplitude. This is also true of the Maxwell stress tensor.
When a classical EM wave is Doppler-shifted due to motion of the source or observer, the power changes. This is the rate of Energy flow or flux through a surface in Watts (joules/second).
The energy of a classical EM wave depends on its amplitude and its volume. When you do a Lorentz boost, both the amplitude and the volume change, and therefore the energy changes.
It occurs to me now that there is a much more elementary argument that the volume of a light wave scales in the way it does. Suppose that a finite wave train of length x takes time t to pass by a certain observer. Since the speed of light is constant, any scaling factor applied to t must also be applied to x when we change frames.
I would speculate that the reason for the complication in Einstein's argument is that he knows that a wave-train with finite volume has to diffract. He wants to show that his result is exact, not some kind of approximation that only applies in the limit of small diffraction effects.
harrylin said:
The result should also be valid - as Neuenschwander suggests in his fig.3 - for the integral of all light inside a radius from the light source to the observer.
Neuenschwander's discussion makes no sense, especially his fig 3. In that figure he shows a spherical surface expanding at the speed of light, and then suggests that this expanding sphere transforms into an expanding shortened ellipsoid in terms of a different reference frame - but of course that's not true. An expanding sphere of light in terms of one system of inertial coordinates is an expanding sphere of light in terms of ANY system of inertial coordinates. So his contracted ellipsoid in the primed coordinates consists of a locus of non-simultaneous events in those coordinates. In other words, his "one wavelength surface" isn't a coherent surface in the primed coordinates, so he can't just integrate the transformed energy density within this "surface" at a single instant of time in the primed coordinates. Also, he obviously can't use a constant energy density, nor even a constant ratio of energy densities between the primed and un-primed systems, because even the ratio varies from point to point.
He obviously doesn't realize any of this, because he depicts the ellipsoid as shortened, whereas the volume formula he gives (which he obviously just lifted from Einstein's paper without comprehension) is the equation for an *elongated* ellipsoid. Worse still, he then multiplies this by Einstein's ratio of energy densities, which obviously is not applicable here, first because the ratio varies with position thoughout the sphere, and more importantly because it doesn't apply to loci of non-simultaneous spatial regions, which is what Neuenschwander's ellipsoid represents in the primed coordinates. So it wouldn't even be correct to integrate Einstein's energy density ratio over the "volume". Basically, Neuenschwander's discussion is gibberish.
Of course, one could make a valid derivation of the energy of an expanding pulse, but it would not bear any resemblence to Neuenschwander's discussion. One simple approach would be to carry out Einstein's derivation for an infinitesimal region, from which the general result follows immediately.
Samshorn,
There's little doubt that Neuenschwander could have done a better job in stating what his figure 3 represents. As worded, and as depected, there are indeed problems with it. I'm not yet convinced his paper is incorrect otherwsie though. I'll need a little more time with it. It's interesting that his paper obtains the same result while starting with the initial assumption I did, ie that the radius R represents and expanding lightsphere from origin. It would seem the result "should" be the same. If so, then the big question is ... which approach did Einstein envision when he wrote his paper.
GrayGhost
He's quite clear about what he thinks it represents - he's just utterly wrong, as is his entire discussion on the energy transformation.
No, his paper doesn't "obtain" the same result. He gives some completely erroneous verbiage, and then merely appropriates Einstein's equations, which are completely unrelated to his verbiage. (See my previous message.) Furthermore, the energy ratio for the case of an expanding sphere is NOT the same as for the moving light complex - it is simply E'/E = 1/sqrt[1-(v/c)^2], so he didn't even get the right answer for the situation he thought he was solving.
It may "seem" that way to you, but you're wrong. The answer for an expanding light pulse is not the same as for a light complex of the kind Einstein discussed.
You're not making any sense. Einstein's paper clearly and explicitly describes the energy content of a spherical region of constant radius moving along with a plane wave. He correctly derives the ratio of the energy content relative to two different frames of reference. Neuenschwander describes a completely different situation, and makes several huge conceptual errors (described in detail in the previous message), and arrives at the wrong answer (not surprisingly).
It's just sad that students are exposed to that kind of nonsense.
Samshorn,
Well, you do sound pretty sure of yourself. You're right, the ellipsoid cannot encompass the EM complex under Neuenschwander's interpretation of the section 8 scenario, assuming that the ellipsoidal surface per the moving system represents a spherical surface that precisely coincides with the leading edge of expanding spherical wavefront in the stationary system (at any arbitrary time t). Here's the thing though ...
Is Neuenschwander "that bad" that he does not know light is isotropic, or does his figure 3 maybe represent something a little different from what you assume it does? I must say, his figure 3 doesn't make sense to me either, and the related description seems bad at best. Let's face it, the rocketeer does not record anything indicative of what he depicts there. It suggests he does not understand the desynchronisation of moving bodies, however that's also hard to swallow. If he really does have some sort of intent that we don't quite realize, I cannot imagine teaching it as such. Who is this fellow, Neuenschwander, anyways?
EDIT: There is only 1 way to interpret Neuenschwander's figure 3b as drafted. However, it cannot exist as such per any frame's POV, including the rocket's POV, and is thus contrary wrt his assertion that the rocketeer sees it as such.
GrayGhost
GrayGhost said:
Samshorn,
GrayGhost
Isn't that clear by now? As discussed, everything(?) is consistent with the interpretation that Einstein continued his discussion of a planar wave originating from "an infinitely distant" light source, while more than a few things are inconsistent with Neuenschwander's interpretation.
Harald
I emailed Neuenschwander a few days ago to let him know about the error. He replied cordially and said he'd take a look at it. I don't think it's unpardonable that he made this mistake, since almost everyone who posted in this thread (including me) initially misread the paper in the same way. I think it's commendable that he wrote this commentary, complete with hand-drawn illustrations, and made it available for free on the web. It would only be really unfortunate if he failed to correct the error.
harrylin,
It's clear to me, now. I had never looked at sections 7 and 8 before, except at glance. I too originally suspected the energy-enclosing-surface corresponded to the leading edge of an expanding EM lightsphere. Now, it seems to me that it cannot be the case. The plane wave appears the logical intention of Einstein, based on the eqn he drafted and the requirement that the spherical surface always enclose the EM complex in both systems.
I tried to follow it thru assuming my original interpretation. Say the enclosing surface is expanding and spherical. For any time t, the spherical surface maps to a moving contracted ellipsoid per the rocket POV. However, considering the spherical surface at time t ... then when the EM intersects it simultaneously per the LAB (let's assume this occurs after precisely 1 wavelength of EM was generated, as Neuenschwander did), we might consider each photon's intersection as "an event". The mapping of "all said events", would be an elongated ellipsoid (not moving) in the rocket POV, however the events would not all occur at once. The events would occur as follows ... imagine a plane-surface parallel to the Y/Z plane, and move this plane in the direction of +x such that it passes thru the elongated ellipsoid while considering only the intersection of the 2 surfaces. That's the order of event occurances. Just guessing here, but maybe Neuenschwander intended to draft something such as that? Yet, said ellipsoidal surface would not exist per the rocket observer in the way Neuenschwander depicted it.
GrayGhost
The cartoons are very good. I especially like how the lab rat raises his arms when the rocket flies by, and the CAPT of the starship wears a hat. He doesn't have to worry about windage blowing the hat off :) I also wonder what he meant by his depicted frame-rotation?
GrayGhost
