arivero
- Messages
- 3,502
- Reaction score
- 205
Molon Labe said:In this paper http://arxiv.org/PS_cache/hep-ph/pdf/0207/0207124v1.pdf Witten states:
"Of the five exceptional Lie groups, four (G2, F4, E7, and E8) only have real or pseu-
doreal representations. A four-dimensional GUT model based on such a group will not
give the observed chiral structure of weak interactions."
Can someone, in a general sense, explain how Lisi purports to work around this? That is, how does Lisi produce the "observed chiral structure of weak interactions"?
This is absolutely not a challenge to Lisi. I have little understanding of this and I am simply trying to make connections.
Thanks for suggesting this reading! I'd add that people interested on GUT should also look for a collection of reprints done by Zee time ago and published with a black soft cover in two volumes (but GUT is mainly the first one).
The chain in formula 7 of Witten paper is the traditional argument up to E8. Also some SO(2n) chains, not only in extra dimensions -as Witten says in the next page- but also in four dimensions. It was not clear if the need extra dimensions were, after all, a question of interpretation. What happens with SO(12) and SO(16) is that they are able to reproduce V-A, but they also have V+A interactions and you must break them. But yes, it seems that the restoration of hopes for E8xE8 come exclusively for extra dimensional theories, because Witten found a way to break the symmetry not into E8 but into a subgroup of E8 getting at the same time only V-A unbroken, and this was using very peculiar choosings in the compactification of the extra dimensions. Not peculiar enough, regretly, and then string theory went to its current stalemate situation. This resumes the rest of the paper.
Now, the point is about a subgroup inside E8xE8, and at the current level of development, even the E8 of Lisi could have some role; do not forget stringers have been very good about taking developments from other fields. A non trivial inclusion [tex]E8 \subset E8 \otimes E8[/tex] (not the obvious trivial one) could in turn be a clue to the right choosing of the V-A compliant subgroup.
Why do I still expect something in E8xE8? Because if you look ot representation level, this is build as pair of particles. And then the known peculiarity of quark pairs in the standard model is that all of these pairs, for the five lightest quarks, reproduce again, with the exact counting of degrees of freedom, the particle content of the standard model (only that if taking literally, all these pairs are bosons). This is a very particular (can not tell if "exceptional") point that only happens with three generations and five light quarks.
