What Determines the Distance for Matter-Antimatter Annihilation?
The discussion centers on the conditions necessary for matter-antimatter annihilation, specifically the proximity required between particles and antiparticles. It is established that the wave functions of the particles must overlap for annihilation to occur, rendering the concept of distance less meaningful. The strong force governs proton-antiproton annihilation, with an upper bound distance of approximately 1 femtometer, although the wave function can extend beyond this range. Annihilation does not take time; it either occurs or does not, and particles with nonzero orbital angular momentum cannot annihilate until they reach a state of zero angular momentum.
  • Quantum mechanics principles, particularly wave functions
  • Understanding of particle physics, including strong force interactions
  • Knowledge of annihilation processes in high energy physics
  • Familiarity with scattering cross-section concepts
  • Research quantum mechanics and wave function overlap in particle interactions
  • Study the strong force and its role in proton-antiproton annihilation
  • Explore the concept of scattering cross-sections in particle physics
  • Investigate the implications of orbital angular momentum on particle annihilation
Physicists, researchers in particle physics, and students studying quantum mechanics and high energy interactions will benefit from this discussion.
Funestis
Hello all. I had some questions on some of the specifics of matter-antimatter annihilation. I've tried looking this up but haven't had much success. If you guys know of any textbooks or journal articles that dig deep into the mechanics I'd be grateful if you'd post them.
Anyway, my basic question is does anyone know how close a particle and antiparticle have to be to one another for annihilation to occur? Does that distance depend on the specific particles involved? I'm assuming that there's some probabilities involved as well (e.g. if a particle/antiparticle pair are x meters apart they have a 10% chance of annihilation, if they are x - y meters apart they have a 50% chance of annihilation, etc.) but I'm uncertain. Any info you guys have would be much appreciated.
~thanks
So close that quantum mechanics makes that concept meaningless. Their waves functions have to overlap.
I figured that much, but how much overlap is there? If there's only a slight amount of overlap is annihilation absolutely guaranteed? What about protonium - I have no idea what the distance is which the proton and antiproton orbit one another, but given that a protonium atom can exist for a short time is it reasonable to ask how long annihilation takes? As I understand it, proton-antiproton annihilation occurs via the strong force, so is it a valid assumption then to say that an upper bound on the distance between particles before an annihilation event could occur would be the distance over which the strong force dominates (1 femtometer)? What about electron-positron annihilation?
In high energy physics we have the notion of cross section for a given process such as ##\ \ e^+e^-\rightarrow X\ \ ## to help in imagining the transition probability as a kind of collision. Much better than trying to get your head around overlapping wave functions. See e.g. particle data group
In some formulae for quark-antiquark aniquilation inside a meson, they use the expresion \Psi(0), which seem to imply that the two quarks must be in the same point. But again, given that both particles are spreaded along the wavefunction, I guess we should integrate across all the possible points.
No.
It does not take time. In any time frame you consider, it either happens or does not happen (to a very good approximation, as protons are not elementary particles).
No, the wave function can be spread out much more, so "distance" becomes meaningless earlier.
The probability of wave functions of two particles overlapping is exactly zero whenever they possesses a nonzero orbital momentum relative to each other.
Is annihilation of particles with orbital angular momentum completely and unconditionally impossible, i. e. particles always have to reach a state with zero angular momentum separately, before they can annihilate?
Why is that?
Imagine a measurement of both positions at the same time. If the two particles are at the same place, no matter what their (not well-defined) velocity is, how can they have orbital angular momentum?
I'm sure there is some higher order effect taking this orbital angular momentum with a virtual photon or whatever, but that doesn't look like a frequent process. States with orbital angular momentum are not the ground state, they can decay quickly.
well, in electromagnetic transitions in the hydrogen atom of course the orbitals are orthogonal, but we do not project a wavefunction over the other, we have also a interaction factor, the photon field in this case, between both.
For phenomenological descriptions, this is a scattering problem and in general characterised by a scattering cross-section, which is a Lorentz invariant quantity. The notion of distance is not as useful, since it is not invariant, so there is no 'universal distance' of scattering. I think any decent particle physics textbook contains this kind of information.
  • · Replies 18 ·
