- Messages
- 1,956
- Reaction score
- 233
I am a little uneasy with the quote in 118 for a number of reasons. The local vs global thing is a bit of a red herring.
First of all, working with linearized gravity does not preclude cosmological or vacuum black hole solutions in any way, nor does it require an R^4 topology. Those solutions are readily studied, and in fact entire textbooks have been written on those solutions (see eg Weinberg 'Gravitation')
However it is true that GR does not in general, uniquely constrain the topology of spacetime. That is additional structure is necessary to fix the exact physics (eg by appealing to experiment).
But not so fast! Working with the standard formulation has the exact same problem! That is why for instance in the case of cosmology, it is still an open question what the exact topology of the universe is like. There is no extra physical information that one formulation gives over the other, which is why they are isomorphic mathematically.
The real fundamental difference (between any of the tens of different formulations of GR) is that in some cases using one formulation allows you to solve problems in a more straightforward way.
You wouldn't want to appeal to the geometric theory to solve the classical black hole merger problem for instance. You want a heavy dose of linearized perturbation theory to tackle that (and a very good computer)!
However trying to prove singularity theorems alla Hawking-Penrose, is more or less completely opaque if all you could see were infinite series of curvature invariants.
So anyway, this whole story is pretty well understood classically. The real question is what happens when you introduce quantum mechanics? And indeed, theorists have tried quantizing pretty much every single formulation of gravity out there, so far unsuccessfully and indeed it is perhaps the case that they give unitarily inequivalent theories.
