Are These T-Test and Effect Size Calculations Correct?
  • Thread starter nobahar
    T-test
2 replies · 8K views · last reply
nobahar
Hello! I hope it's okay to ask stats questions...
I think the calculations are correct, but I would appreciate it if someone could check for me!
These are the results from the exp. using repeated measures. My hypothesis is that the reuslts in condition 2 should be less than condition 1.
Cond 1
49
41
42
44
44
42
66
57
44
66
66
59
Cond 2
43
39
36
42
48
41
38
44
34
40
32
43
I know working out the standard deviation is tedious, but I checked with excel and it matched (I used n-1, so I got the population, not just the sample).
So, for condition 1:
mean=51.66666667
s.d.= 10.36895132
standard error= 2.99325842
and condition 2:
mean= 40
s.d.= 4.51260859854
standard error= 1.30267789
These (I think) are correct, its the t-test, p value and effect size I would greatly appreciate some feedback for.
For the t-test I used the realted t-test, since its repeated measures (same participant in both):
Formula for a paired t-statistic: (mean 1 minus mean 2) divided by (standard deviation of the difference over the square root of N), followed by the same formula with values 155/3 minus 10 over (12.078029138845 divided by the square root of 12).
I got t= 3.346118674
are the units sd?
and DoF would be 11, and since I specified a direction, I got p=0.003261139 (one-tailed); which is significant? since P is less than 0.05?
and for effect size:
Formula for Cohen's d: (mean 1 minus mean 2) over the average of the two standard deviations, with the values substituted as (155/3 minus 40) over (14.88155992040 divided by 2).
I got (d)= 1.567935986
Can someone verify the t-test, effect size and p value for me? Please! I used fractions at some points where I could quickly get the data (I wrote it down), in ideal circumstances should I use fractions for all the 'inputs' (e.g. stand. dev of difference, etc.), if possible, since its more 'accurate'?
Thanks! I now it's a lot to ask, but I would geratly appreciate it! I realize the formuale are slightly different depending on the narue of the experiment, I think I chose the right ones!
It's been a while since I've done anything with statistics, but I think you might not be using the right form for t. The form I've included is for a two-sample t test, which seems to me the right one for your problem.
Instead of the standard error, I think you might need to use a pooled standard deviation.
[tex]t = \frac{X - Y}{S_p\sqrt{\frac{1}{12} + \frac{1}{12}}}[/tex]
where X and Y are the sample means for the two conditions, and [tex]S_p[/tex] is the pooled s.d., which is given as
[tex]\sqrt{\frac{(n - 1)s_x^2 + (m - 1)s_y^2}{n + m - 2}}[/tex]
For your problem, n = m = 12.
Your use of fractions and decimal values probably won't affect your values, since you apparently used quite a few decimal places in your calculations.
The t distribution is close to a normal distribution with mean 0 and s.d. 1. For n around 30 there's no difference between the two distributions. That should answer your question about units of s.d.s.
Hope this is helpful.
Thanks for the response!
I've got to do some reading... I haven't come across (or I don't think I have) the pooled s.d. yet.
I kow the related and independent t-tests. The latter being the (mean 1 - mean 2)/sqrt{(variance 1/n1)+(variance 2/n2)}.
