Assessing experimental validity and improvement
  • Thread starter mani88
    Scientific
7 replies · 2K views · last reply
mani88
Hi everyone, I just wanted to know how would I answer assess questions. So for example: Assess the validity of your experiment or Assess the reliability of your experiment or Assess the accuracy of your experiment. What would be the first step in answering these kinds of questions? How would I approach these kinds of questions? What can I talk about?
Thanks
Assess: Consider the value or importance of something, paying due attention to positive, negative and disputable aspects, and citing the judgements of any known authorities as well as your own.
Assess the validity of this experiment and suggest ways in which it can be improved.
The experiment was fairly valid as the experimental design tested the aim and all variables apart from those being investigated were kept constant.
Now you would elaborate on this statement through evidence, etc
'Access' and 'Assess' are two different words with different meanings.
Also, please post one example and show your attempt. It is mandatory for the OP to show their work in the HH forums here.
PS: Welcome to PF!:smile:
State any reasons you can find that might make the experiment invalid.
Consider the sources and magnitudes of error in your measurements and the consequences for the result.
Thanks for your help but how would I start my topic sentence in a scientific way? Is it something like The experiment was fairly valid...or The experiment was not valid... How do I write these in a scientific way?
oh sorry... It's assess.
An example would be: Assess the validity of your experiment and suggest ways in which it can be improved.
Attempt: The experiment was fairly valid as the experimental design tests the aim and all variables apart from those being investigated were kept constant.
Something like this and then you would elaborate
That suggests it was not completely valid, so I would expect to read next some reasons it might not be.
Maybe you could post a specific example.
Would this be a good response??
The following investigation was valid as the experimental design tested the aim and all variables apart from those being investigated were kept tightly constant to stop them from affecting the results. The internal/criterion validity of this experiment was very high as the experimental design was well structured and encompasses all the steps of the scientific research method. The control variables were also kept tightly controlled as possible such as the table used, the ruler used and the slow motion device used. The external/ecological validity was also very high as the results showed a direct relationship between frequency and pitch, and amplitude and loudness like described in the hypothesis. Additionally, the validity can also be determined by looking at the reliability of this investigation.This practical was very reliable as repeated trials gave similar results. The results from the trial were then averaged to further increase the reliability of this experiment. In conclusion, this investigation was valid due to having a high internal and external validity and a high reliability.
Sounds good, even excessive, but whether it is appropriate depends on the actual experiment.
