MHB Solving IVP $y''-y=0$ with $y_1,y_2$
  • Thread starter Thread starter karush
    Ivp
karush
MHB
$\tiny{b.1.3.7}$
Solve IVP
$y''-y=0;\quad y_1(t)=e^t,\quad y_2(t)=\cosh{t}$
$\begin{array}{lll}
&\exp\left(\int \, dx\right)= e^x\\
& e^x(y''-y)=0\\
& e^x-e^x=0\\ \\
&y_1(x)=e^x\\
&(e^x)''-(e^x)=0\\
&(e^x)-(e^x)=0\\ \\
&y_2(x)=\cosh{x}\\
&(\cosh{x})''-(\cosh{x})=0\\
\end{array}$
ok there was no book answer so hopefully went in right direction so suggestions...:unsure:
That method doesn't work for second degree equations. Use the method of characteristics.
We have y'' - y = 0. So write [math]m^2 - 1 = 0[/math]. This has solutions m = -1, 1. Thus the homogeneous solution will be
[math]y_h = A e^{1 \cdot t} + B e^{-1 \cdot t}[/math]
To fit the particular solution you can look at the method of undetermined coefficients. Hint: Let [math]cosh(t) = \dfrac{1}{2} ( e^{t} + e^{-t} )[/math].
-Dan
-Dan
so we can do this?
$\dfrac{1}{2} ( e^{t} + e^{-t} )=A e^{1 \cdot t} + B e^{-1 \cdot t}$
Hmmm... Apparently the whole method isn't contained in what I quoted.
If you have a term [math]Ae^{t}[/math] in [math]y_h[/math] then you can't have that term in [math]y_p[/math]. (Think about it... If you use [math]e^t[/math] in your particular solution then it will just give 0 because it is already in the homogeneous solution.) So instead of using [math]e^t[/math] try [math]te^t[/math]. If that doesn't work or if you need it (in this case you will) try [math]t^2 e^t[/math], etc.
-Dan
$Ae^{1- t}= Ae^1e^{-t}$ and the constant, e, can be "absorbed" into "A"; $A'= Ae$ so $Ae^{1- t}= A'e^{-t}$.
Similarly $Be^{1- t}= B'e^{-t}$ with $B'= Be$.
And, of course those can be combined: $A'e^{-t}+ B'e^{-t}= Ce^{-t}$ with C= A'+ B'
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
