Basic counting methods — integers between 1 and 100 that are divisible by 7
  • Thread starter Thread starter stunner5000pt
    Counting
19 replies · 3K views
stunner5000pt
Pick two integers between 1 to 100 (inclusive) whose product is divisible by 7. No repetition allowed
Determine the number of numbers that may be formed this way
There are 14 integers between 1 to 100 that are divisible by 7
If we used indirect approach, then we would do the total number of possibilities C(100,2) = 4,950
and subtract all nubmers that are indivisible by 7 : C(100-14, 2) = C(86,2) = 3,655
the difference of these two numbers is 4,950 - 3,655 = 1,295
Is this the right answer?
Your insight is greatly appreciated!
stunner5000pt said:
Homework Statement: Pick two integers between 1 to 100 (inclusive) whose product is divisible by 7. No repetition allowed
Relevant Equations: Basic counting methods
Kind of depends on the question -- which you forgot to mention ?
If the product is divisible by 7, then at least one of the numbers must be divisible by 7. As you said, there are 14 integers in the interval [1 ... 100] that are multiples of 7. You don't want C(100, 2) since you're not going to pick just any 2 numbers out of the 100 of them.
The condition that "No repetition allowed" likely means that we shouldn't count 7 * 7, 14 * 14, and so on.
Sorry about this. Added that question as well
Further to Mark44's comment, the answer I got still seems to be double counting the 7x7, 14x14, and so on
Is it as simple as dividing the result by two ?
stunner5000pt said:
1 Sorry about this. Added that question as well
2 Further to Mark44's comment, the answer I got still seems to be double counting the 7x7, 14x14, and so on
3 Is it as simple as dividing the result by two ?
1 makes my post#2 look dumb :frown:
2 Which is what he says:
3 What result ?
Furthermore, you should also decide if for example, the pair 8,7 is the same as the pair 7,8
Maybe you can split into two cases for the product ab; when they're both divisible by 7, and when only one is. They're disjoint, i.e., they don't overlap.
The statement Mark44 made generalizes to primes. If p is a prime and p|ab , then p|a or p|b.
and subtract all numbers' that are indivisible by 7 : C(100-14, 2) = C(86,2) = 3,655
I get the same answer as you got, but used a different method of counting.
Also, I assumed, for example, that the pair 7,8 is the same as the pair 8,7. Furthermore, I only considered integers in each pair to be distinct, not allowing pairs such as 7,7 or 98,98 .
So, on a checkers board with 104 fields, there are 14 rows and 14 columns that satisfy "product divisible by 7". You can paint them yellow, and when you're done you have painted 2800 - 14*14 = 2604 fields. To avoid repetition, you don't paint the 14 diagonal fields.
Right answer is 2590 :biggrin:
I interpret this as the number of distinct final products. There are far fewer of those than the results of the combinatorial calculations above. As most final products can be generated in several ways.
Well, yes, if you insist on actually reading what the problem states and complying with that.
o:)
This will require some clever analysis of possible prime factors.
So either some of us, who arrived at the result of 1,295 half-counted , or you double-counted.
I had this idea of counting all multiples of 7 up to some amount, as the set of products pq, where at least one of p,q , is divisible by 7.
Still, as @PeroK mentioned, if I understood correctly( please correct me if I misunderstood) , would you consider 98=14(7)=49(2) as different numbers obtained as products?
If they're considered different, it seems you may have to use the likes of the Euler Phi function.
It's a matter of choice; I found the problem statement ambiguous at best.
Reply
Determine the number of numbers that may be formed this way.
I think it's pretty clear that @PeroK's interpretation of the problem is probably what was intended.
As he pointed out in Post#10:
For example the product of 21 and 84, which is 1,764, also results from multiplying other pairs of integers between 1 to 100 (inclusive).
Those pairs are: {28, 63}, {18, 98}, {36, 49}, and maybe {42, 42} .
So, if counting distinct products is what is intended, then these several pairs taken together all count as giving one single product.
As he pointed out in Post#10:For example the product of 21 and 84, which is 1,764, also results from multiplying other pairs of integers between 1 to 100 (inclusive).
And I think something like the Euler Phi function will be involved.
No: for instance you have counted the number 42 three times (2 x 21, 3 x 14, 6 x 7). The correct answer is a little more than half of 1,295.
And you have counted 42 six times (2 x 21, 3 x 14, 6 x 7, 7 x 6, 14 x 3, 21 x 2).
I don't think there is a quick way to find the answer manually, but generating a list without duplicates is something that computers are good at doing.
Reply
Generating your list without duplicates looks more reasonable than trying to use some system of looking at unique prime factorizations to look for and eliminate duplicates.
Also, notice that missing from your lists is 1×42 .
Reply
Yes, this illustrates well the difficulty of getting things like this right by hand - even if you have 50 years experience of problem solving it is easy to miss obvious things.
But half a dozen lines of code in your favourite programming language gets the right answer straight away.
Reply
