Basic First ODE and Separation problem
  • Thread starter Thread starter Gulfstream757
    Ode Separation
The discussion revolves around two differential equations: the first involves verifying a proposed solution for a specific boundary condition, while the second requires solving a differential equation with an unclear expression on the right-hand side. The subject area is ordinary differential equations (ODEs), specifically focusing on separation of variables and boundary conditions.
  • Participants discuss the need to differentiate the proposed solution and check if it satisfies both the differential equation and the boundary condition. There are questions about when to apply the boundary values. For the second equation, there is confusion regarding the expression on the right side, with participants seeking clarification on its format and discussing the separability of the equation.
Some participants have provided clarifications regarding the interpretation of the equations and the nature of the boundary conditions. There is ongoing exploration of how to separate the second equation, with some suggesting that it may not be separable in the traditional sense. Multiple interpretations of the second equation are being considered, and participants are sharing their attempts to clarify the problem.
There is ambiguity in the notation used for the second differential equation, leading to confusion about its separability. Participants are encouraged to use clearer formatting to avoid misunderstandings. The original poster has expressed difficulty in applying the boundary conditions and separating the equations, indicating a need for further guidance.
Gulfstream757
<Moderator's note: Moved from a technical forum and thus no template.>
Hi all, hope you all had a great Christmas,
I had a difficulty with theses two problems,
1. Show that y=1/x + x/2 is a solution of the differential equation,
dy/dx=1-y/x, where y=1.5 and x=2
2. Solve the differential equation, dy/dx=e^4x-y, where y=1 and x=1/4
In your final answer express y in terms of x.
For question 1 my understanding is that I should differentiate the y= function and then sub that in for dy/dx and they should equal with some algebra. My problem is when do you input the values for x and y?
For question 2 I think its a separable equation that you would separate, integrate to solve then sub in the x and y values to find the constant of integration. My issue is how to separate, I've tried to take the natural log of both sides? But I am really lost
Thanks so much in advance!
Gulfstream757 said:
where y=1.5 and x=2
This is pretty bad nomenclature because y and x are not constants so it is not that you should insert this into the differential equation. Instead, it would seem that this is supposed to give the boundary condition, i.e., that y = 1.5 when x = 2. You then need to show that the function y both satisfies the differential equation as well as the boundary condition (a priori, you could have been given a function that satisfies the differential equation but not the boundary condition). Hence, you need to check that both the differential equation and the boundary condition are satisfied.
It is not clear to me what you mean by e^4x-y. Do you mean e^(4x)-y, (e^4)x - y, e^(4x-y), or something else? Please use parentheses or LaTeX to avoid any misunderstanding. Also, please show what you tried and what you got from trying.
If your second equation is ##dy/dx = e^{4x} - y## then it is, indeed, "separable", and re-writing it as ##dy/dx + y = e^{4x}## makes it clearer. If your second equation is ##dy/dx = e^{4x-y}## then it is not separable in any standard sense.
The way you wrote it, the first form is what one would get applying standard math parsing rules; however, using parentheses never hurts and can sometimes help.
That is not a separable ODE. A separable ODE can be written on the form ##y' f(y) = g(x)##, where ##f## and ##g## are some functions. You can then solve the differential equation by integrating from ##x_0## to ##x## according to
\int_{x_0}^x g(\xi) d\xi = \int_{x_0}^x y'(\xi) f(y(\xi)) d\xi = \int_{y(x_0)}^{y(x)} f(y) dy,
where the last step is a change of variables in the integral.
That, on the other hand, is separable. I will not do it as it is something the OP should do for himself.
The expression on the right side of the equation is ambiguous. Because many new members here don't realize the importance of using parentheses, it's hard for us to know exactly what you mean when you write e^4x-y.
This could be any of the following:
##e^4~x - y##
##e^{4x} - y##
##e^{4x - y}##
I've written these using LaTeX. Writing the 2nd and 3rd as inline text, they would be e^(4x) - 4 and e^(4x - y).
You are right: I am somewhat sloppily using the term "separable" when looking at a nonhomogeneous DE whose homegeneous version is separable, although, of course, it is not separable officially. And, of course, I spoke too soon about the second DE. Blame the lack of morning coffee.
I agree that the homogeneous version ##y' + y = 0## is separable, but perhaps even more relevantly, it has an integrating factor ##e^x## such that ##d(e^x y)/dx = e^x(y' + y)##. Multiplying both sides by ##e^x## therefore gives ##d(e^x y)/dx = e^{5x}##, which is easily integrated.
Orodruin said:
This is pretty bad nomenclature because y and x are not constants so it is not that you should insert this into the differential equation. Instead, it would seem that this is supposed to give the boundary condition, i.e., that y = 1.5 when x = 2. You then need to show that the function y both satisfies the differential equation as well as the boundary condition (a priori, you could have been given a function that satisfies the differential equation but not the boundary condition). Hence, you need to check that both the differential equation and the boundary condition are satisfied.It is not clear to me what you mean by e^4x-y. Do you mean e^(4x)-y, (e^4)x - y, e^(4x-y), or something else? Please use parentheses or LaTeX to avoid any misunderstanding. Also, please show what you tried and what you got from trying.
Sorry for only getting a chance to reply now, I've attached my attempts, I know it looks like I haven't put i
Apologies I only got a chance to reply now, please see the photos attached, as you can see I'm really stuck! Thanks in advance for any help!
The equation as written is separable, so you should start by separating it. Once you have done that it canbe integrated without problems in the manner described in post #4.
You are already getting into a bad habit: posting images instead of typed work. Please avoid that in future, especially if you are serious about wanting help. (See the post "guidelines for students and helpers", by Vela, which is pinned to the start of this forum, for various reasons related to this issue.)
  • · Replies 25 ·
