Bell curve program for height and weight in MATLAB
  • Context: MATLAB
  • Thread starter Thread starter Jamin2112
    Matlab
2 replies · 3K views
Jamin2112
So I've been just screwing around and having fun with this newfound software package and the introduction book that I bought at the bookstore. I decided to make a program that takes in a user's height and weight, then shows their place on a bell curve.
Here's what I have so far:
First help me figure out the error. Basically it doesn't like row 28 because "inputs must be a scalar and a square matrix."
Then help me figure out how to plot a graphic that shows a shaded area under the curve to the left of the user's percentile mark.
Thanks in advance!
Thanks in advance!
MATLAB treats objects as matrices. Let's say you assign the result of v^2 to another object. If v is not a square matrix, it will throw an output error.
It seems what you want to do is use the element at a given index and output your final value in the output vector at the same index.
So instead of using say v^2 you would use v.*v. Look up the help section and look for piecewise operations that have ".*" or "./" or something with a dot, and that should output another vector where the index of the output corresponds with the one-dimensional real function given the input that was obtained by your input vector.
So you should end up with two vectors, one with input (x) and one with output (y), both with same dimensions which is what you want.
Use the .^ operator for element-by-element exponentiation.
