Binomial expansion of term with x^2
The discussion centers on finding the coefficient of the term x^18 in the binomial expansion of (1/14 x^2 - 7)^16. The correct approach involves using the binomial theorem, specifically the general term nCk a^k b^(n−k). Participants clarify that the coefficient can be derived by letting y = x^2, leading to the expression 16C9 (1/14)^9 (-7)^7. Misunderstandings regarding the calculation of binomial coefficients, particularly 8C9, are addressed, emphasizing that 8C9 is invalid since k cannot exceed n.
  • Understanding of binomial expansion and the binomial theorem.
  • Familiarity with binomial coefficients (nCk) and their calculation.
  • Basic algebraic manipulation involving exponents.
  • Knowledge of Pascal's triangle and its properties.
  • Study the binomial theorem in depth, focusing on its applications in polynomial expansions.
  • Learn how to compute binomial coefficients using the formula nCk = n! / (n-k)!k!.
  • Explore the concept of generating functions and their relation to binomial expansions.
  • Investigate the properties of Pascal's triangle and its use in combinatorial mathematics.
Students and educators in mathematics, particularly those focusing on algebra and combinatorics, as well as anyone needing to understand polynomial expansions and binomial coefficients.
Roodles01
I have to determine the coefficient of an x term in an expansion such as this;
Determine the coefficient of x^18 in the expansion of (1/14 x^2 -7)^16
The general term in the binomial expansion is
nCk a^k b^(n−k)
I could let
a = (1/14 x^2)
b = -7
n = 16
k = 9?
I have no real idea of how to go about finding this coefficient using the binomial theorem.
Having expanded the expression to the 10th term I get
8C9 (-7) (1/14 x^2)^9
I'm using nCk = n! / (n-k)!k! but can't evaluate this as it is a negative.
I'm assuming that the 8C9 bit is just the opposite of 6th term i.e. 12C5 = 792 (looking at Pascal's triangle this is on the opposite side), but I can get the x^18 bit (I'm assuming the (x^2)^9 can be x^18 here)
Can someone check, please?
nCk a^k b^(n−k)
I could let
a = (1/14 x^2)
b = -7
n = 16
k = 9?
Conventionally, nCk for integers 0 < n < k is regarded as zero. Why did you write 8C9?
RGV
If you let y= x^2, then you are looking for the coefficient of y^9 in ((1/14)y- 7)^16.
That will be, of course, 16C9 (1/14)^9(-7)^7
Of course you are right HallsofIvy.
I was doing this
(OK I put the 6th term when I meant 7th)
I put 8C9 as I understand that when I expand the expression (1/14 x^2 - 7) longhand I get;
-7^16 + (16C1*-7^15*(1/14 x^2)) + (15C2*-7^14*(1/14 x^2)) + . . . . + (11C6*-7^10*(1/14 x^2)) + . . . . . . . . + (8C9*-7^7*(1/14 x^2)) . . . .
Where (11C6*-7^10*(1/14 x^2)) is the 7th term of the expansion
& (8C9*-7^7*(1/14 x^2)) is the 10th term
Pascals triangle, being symmetrical, should reflect the coefficients around the8th & 9th terms. So I'm assuming that the coefficient of the 7th term should be the same as the 10th term.
When I try to calculate 8C9 (which I did longhand, shown above)
I use form nCk = n! / (n-k)!*k!
If I let n=8
& k=9
I get 8!/(-1)!*9!
I work this out to be;
40320 / -1 * 362880 = -0.1
I know this isn't right so why did I do this wrong!
_8C_9 would be the coefficient of a^9 in (a+ b)^8 and there is no such term! Do you mean _9C_8?
  • · Replies 18 ·
  • · Replies 21 ·
