MHB Digital Clocks: Binomial Problem Analysis and Results
  • Thread starter Thread starter Math101_McF
    Binomial
A company producing digital clocks has a defect rate of 5%. When randomly selecting 80 clocks, the expected number of defective clocks is 4. The probability of exactly 6 defective clocks can be calculated using the binomial distribution formula. To find the probability that at least one clock is defective, the complement method is used, calculating the probability that none are defective and subtracting from 1. This analysis emphasizes the application of binomial probability in quality control for manufacturing.
Math101_McF
A company makes digital clocks. It is determined that 5% of all clocks produced are defective.
you go to the warehouse and randomly select 80 clocks.
1. How many of the 80 clocks do you expect to be defective?
2.What is the probability that exactly 6 of the clocks are defective?
3. What is the probability that at least one of the clocks (out of 80) is defective? use the complement.
Hi there,
Welcome to MHB! :)
We like to tackle one problem at a time. Which one do you want to look at? What are your thoughts on it?
Math101_McF said:
Ok so we really want to help you but won’t give you answers. If you show what you’ve done we will do a ton to get you to the finish line but if you want answers for free this isn’t the place.
What we do have here are volunteers with PhD’s, other advanced degrees, and years of experience teaching math. We actually want you to like math and learn. For free. Promise.
The answer is almost given in the question:
"A company makes digital clocks. It is determined that 5% of all clocks produced are defective.
1. How many of the 80 clocks do you expect to be defective?"
5% of 80 is (0.05)(80)= 4.
"2. What is the probability exactly 6 clocks are defective."
Each clock is either "defective" or "not defective" so this is a "binomial distribution". There are 80 clocks. The probability any given clock is broken is 0.05 and the probability it isn't is 0.95. The probability exactly 6 out of 80 are broken is $\begin{pmatrix}80 \\ 6\end{pmatrix}(0.05)^6(0.95)^{74}$.
"3. What is the probability that at least one of the clocks (out of 80) is defective? use the complement."
The opposite of "at least one" is "none". Calculate the probability that none of the 80 clocks is defective, $(0.95)^{80}$ and subtract that from 1.
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
  • · Replies 17 ·
9K
  • · Replies 26 ·
