Bounding rational expressions with absolute value constraints
11 replies · 3K views
bamajon1974
For context, this question is not for homework but in reference to bounding terms for epsilon-delta limit proofs. I know you can bound the numerator and denominator separately but I really would like to know how manipulate the quotient together as I have forgotten some elementary algebra.
Please see below.
How does one manipulate rational absolute inequalities?
For example, I want to transform the absolute value inequality ##|x-3|<1## to ##\frac{|x+3|}{5x^2}<A \ ##, for some number ##\text{A}##, to find an upper and lower bound on the latter term using the constraint in the first term, and not sure what to do with the denominator and changing inequality direction.
I can expand the absolute value inequality as follows: ##|x-3|<1 \implies -1<x-3<1 \implies 2<x<4 \implies 5<x+3<7. ## How do I introduce the ##5x^2## term in the denominator? Dividing all three sides by ##5x^2## would add a variable to the numbers and possibly change signs. Not sure where to go from here.
Thanks!
bamajon1974 said:
Dividing all three sides by 5x2
Sounds like a bad idea. since ##5x^2## is positive (*), multiplying seems more logical: ##|x+3|<5x^2## and you have to study two cases:$$x\le-3 \ \& \ 5x^2 +x+3>0 \quad \Rightarrow x\le -3$$and$$
x>-3 \ \&\ 5x^2-x-3 >0 $$which requires solving a quadratic equation
(*) Edit: Oops, have to exclude ##x=0## :smile:
PeroK said:
Your lower bound for ##x## implies an upper bound for ##\frac 1{5x^2}##
I made a mistake and ##\frac{|x+3|}{5x^2}<A## for some number A to be determined, not 1.
I am guessing you would have to consider the numerator and denominator separately. So for the numerator, ##5<x+3<7## and for the denominator, ##\frac{1}{80}<\frac{1}{5x^2}<\frac{1}{20}.##
Then, can I combine the two expressions, i.e., ##\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20}## and, to find an upper bound? That is, to produce ##-\frac{7}{20}<\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20} \implies \frac{|x+x|}{5x^2}<\frac{7}{20}?## It seems arbitrary to separate the numerator and denominator.
Thanks.
I made a mistake in the original post and corrected. What I want to do is use $$|x-3|<1$$ to bound ##\frac{|x+3|}{5x^2}## and equal to some number.
bamajon1974 said:
I made a mistake in the original post and corrected. What I want to do is use $$|x-3|<1$$ to bound ##\frac{|x+3|}{5x^2}## and equal to some number. Does that clarify?
What's not clear is why this is an issue. Bounding both is precisely what you want to do.
Ok then I should clarify...I understand the process of bounding. The question I have is the algebra involved in bounding, i.e., is it legal to find the bounds f the numerator and denominator separately or as a single quotient. In the end, I found my bounds but the issue was just a side question I asked,
Remember that ##|a| |b|=|ab|##.
Therefore, ## \displaystyle \left| \frac{1}{5x^2} \right| |x+3| = \left| \frac{x+3}{5x^2} \right| ##.
bamajon1974 said:
is it legal to find the bounds of the numerator and denominator separately or as a single quotient.
Whatever works best. As long as you follow the rules of algebra there's no issue.
By the way, it's often possible to simplify these calculations by taking a round number as the bound. E.g. If we have ##2 < x < 4##, then ##\frac 1 {5x^2} < \frac 1 {20} < 1##.
And, as ##| x + 3| < 7##, we have:$$|x - 3| < 1 \ \Rightarrow \ \frac{|x + 3|}{5x^2} < 7$$Which is just as good as ##\frac 7 {20}##.
I think I see now. Equivalently, ##|a/b| = |a|/|b|.## In the context of my question, it is ##|a|/b##, since ## |a|=|x+3|## and ##|b|## is ##|5x^2|=5x^2## which always positive. Given that ##|x-3|<1## and ##|a/b| = |a|/|b|.##, I can find upper and lower bounds of the numerator and denominator separately and combine them back into one single absolute value inequality, right?
Maybe something like this?
If $$|x-3|<1, $$ then $$|x-3|<1 \implies -1<x-3<1 \implies 2<x<4 \implies 5<x+3<7$$ for the numerator and $$\frac{1}{4}<\frac{1}{x}<\frac{1}{2} \implies \frac{1}{16}<\frac{1}{x^2}<\frac{1}{4} \implies \frac{1}{80}<\frac{1}{5x^2}<\frac{1}{20}$$ for the denominator.
Dividing produces $$\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20} \implies -\frac{7}{20}<\frac{5}{80}<\frac{x+3}{5x^2}<\frac{7}{20} \implies \frac{|x+3|}{5x^2}<\frac{7}{20}.$$
