Bug crawling outward on spinning CD before slipping
2 replies · 3K views · last reply
Voltrical
A bug crawls outward from the center of a CD spinning at 200 revolutions per minute. The coefficient of static friction between the bug’s sticky feet and the disc surface is 1.2. How far does the bug get from the center before slipping? What is the speed of the bug just before it starts slipping?
Edited my work as I would use this in class. May post on request.
r = a / w2
r = 2.6666 cm
The bug gets 2.66 cm from the center before slipping.
Q: Does the above seem right? How do I do the second part of the problem where I have to find the speed of the bug before it starts slipping?
How fast is the edge of a circle radius 2.66cm moving if it's rotating at 200rpm?
Oh thank you. I got the correct answer with formula, v = ( r ) ( w ). My teacher put the correct answer on the problem for some reason. Thank you.
