Calculating LCM with Multiple Prime Factors
  • Context: MHB
  • Thread starter Thread starter karush
The least common multiple (LCM) of the numbers A, B, and C is calculated using their prime factorizations. The prime factorizations are as follows: A = 2 × 3 × 7² × 19, B = 2² × 17⁹ × 19⁸ × 23⁸, and C = 2⁶ × 3 × 11⁹ × 19. The LCM is determined by taking the highest power of each prime factor present in any of the numbers, resulting in LCM(A, B, C) = (2⁶)(3)(7²)(11⁹)(17⁹)(19⁸)(23⁸).
  • Understanding of prime factorization
  • Knowledge of least common multiples (LCM)
  • Familiarity with exponent notation
  • Basic arithmetic operations
  • Study the method of calculating LCM using prime factorization
  • Learn about the properties of prime numbers and their applications
  • Explore advanced LCM calculations involving more than three numbers
  • Practice problems on LCM with varying levels of complexity
Mathematicians, students studying number theory, educators teaching arithmetic concepts, and anyone interested in mastering LCM calculations.
karush
MHB
$\tiny{c4.LCM of \{A,B,C\}}$
added image to avoid typo
Build the LCM of $\{A,B,C\}$
Then write the prime factorization of the LCM of $\{A,B,C\}$.
$A = 2 \cdot 3 \cdot 7^2 \cdot 19$
$B = 2^2 \cdot 17^9 \cdot 19^8 \cdot 23^8$
$C = 2^6 \cdot 3 \cdot 11^9 \cdot 19$
$LCM of \{A,B,C\}=\boxed{?}$
ok well to start with $\{A,B,C\}$. all have a common factor of 2 and 19
the lowest of 2 is 2 and the lowest of 19 is 19
so LCM $\{A,B,C\}$.=(2)(3)(7^2)(17^9)(19)(23^8)
NO! For "least common multiple" you take the HIGHEST power of each prime, not the lowest.
so LCM $\{A,B,C\}$ = (2^6)(3)(7^2)(17^9)(19^8)(23^8)
hopefully
however only 2 and 19 are only in all 3 sets?
Yes, so what is your question?
If you were asked to find the least common multiple of 2, 3, and 5, you should respond with 2(3)(5)= 30, even though NONE of those factors are in all 3 numbers.
ok I don't see 5 in there
so then LCM $\{A,B,C\} = (2^6)(3)(7^2)(11^9)(17^9)(19^8)(23^8)$
Lcm is the least common factor the number which is multiples of all numbers for example Lcm of 3 and 4 is 12
the other method is prime factorization.
Step 1: Express each number as a product of prime factors.
Step 2: LCM = The product of the highest powers of all prime factors.Step 1 : Express each number as a product of prime factors.
18 = 2 × 32
24 = 23 × 3
9 = 32
36 = 23 × 32
90 = 2 × 5 × 32
Here the prime factors are 2, 3 and 5
The highest power of 2 here = 23
The highest power of 3 here = 32
The highest power of 5 here = 5
Hence LCM = 23 × 32 × 5 = 360
sumaira, good post but it would be easier to read if you were to use "^" to indicate exponents.
18 = 2 × 32
18= 2 x 3^2 so I won't think that is "thirty two"!
24 = 23 × 3
24= 2^3 x 3
9 = 32
9= 3^2
36 = 23 × 32
36= 2^3 x 3^2
90 = 2 × 5 × 32
90= 2 x 5 x 3^2
2^3
3^2
2^2 x 3^2 x 5= 360
(23 x 32 x 5= 3680!)
yeah i understand next time I will use this notation for power
  • · Replies 18 ·
