Calcium Carbonate in Antacid: Why Higher Yield in Wet Flask?
  • Thread starter Thread starter lmlgrey
The discussion centers on the determination of calcium carbonate concentration in antacid tablets using a wet flask method, which yields a higher concentration than expected. The reaction between hydrochloric acid (HCl) and calcium carbonate produces carbon dioxide (CO2), and the method involves measuring the gas pressure changes using a pressure detector. The formula used for calculations is based on the ideal gas law, specifically the equation nf-ni=(pf'/Tf-pi'/Ti)*V/R, which accounts for the partial pressure of CO2 and other gases present in the flask.
  • Understanding of acid-base reactions, specifically HCl and calcium carbonate interactions.
  • Familiarity with gas laws, particularly the ideal gas law.
  • Experience with pressure measurement techniques in chemical reactions.
  • Knowledge of stoichiometry for calculating moles of gas produced.
  • Research the ideal gas law and its applications in chemical reactions.
  • Learn about the methods for measuring gas pressure in laboratory settings.
  • Explore the stoichiometry of acid-base reactions involving carbonates.
  • Investigate the effects of temperature and volume on gas behavior in reactions.
Chemistry students, laboratory technicians, and researchers involved in analytical chemistry and reaction kinetics will benefit from this discussion.
lmlgrey
1. When determining the concentration of calcium carbonate in an antacid tablet, why using a wet flask will end up with a significant higher concentration?
2. Gas laws
I would expect a lower yeild of gas since some of the calcium carbonate reacts with water and escape from the tube...but higher??
Can you describe the method that you are using? It's hard to answer without knowing how you determine the concentration of calcium carbonate.
A reaction happened between HCl and antacid (which contains calcium carbonate) and the reaction flask was equipped with a pressure detector... by calculating the difference between # of moles of gas in the flask before and after(nf-ni=(pf'/Tf-pi'/Ti)*V/R...
Your pressure sensor measures the pressure of every gas within the flask. It is more proper to say that you are measuring the partial pressure of CO2. What other gases are present in the flask?
11K
15K
24K
