Calculating concentration in molLl^-1 of a solution
  • Thread starter Thread starter leah3000
    Concentration
To determine the concentration of sodium carbonate (Na2CO3) in molL^-1, 53g of Na2CO3 in 500ml yields 1 molL^-1. The solution contains 2 molL^-1 of sodium ions (Na^+) and 1 molL^-1 of carbonate ions (CO3^2-). For preparing a 250ml solution of 0.25M Na2CO3, the required mass is calculated to be 26.5g, not 106g. The correct approach involves using the formula C = n/V to find the number of moles needed for the desired concentration. Understanding these calculations is essential for accurate solution preparation.
leah3000
Determine the concentration in molL^-1 of a solution of sodium carbonate whoch contains 53g of sodium carbonate in 500ml of solution. Calculate the concentration of sodium and carbonate ions in this solution.
no of mols= Mass/Mr
mols= [ ] x vol
1000
Mr= 106
no of mols= 53/106 = 0.5mols
molsx 1000/ vol = [ ]
0.5x1000/500= 1molL^-1
Na2CO3
2mols Na^+: 1mol CO3^2-
I'm usure of how to calculate the rest.
would the conc of Na ion be 2x 1molL^-1 = 2molL^-1
then making the conc of CO3^2- just 1molL^-1?
Looks OK.
Borek said:
Looks OK.
thanks you...
There's another question based on the answer to the first but I'm not sure i understand what it says
How would prepare a 250ml of a .25M solution of sodium carbonate using the sodium carbonate in the quest above. show claclulations.
This is what I did.
Mass= Molsx Mr
Mols= 0.25x1000/250
=1mol
Mass= 1x106
=106g
0.25M= 106g Na2CO3^2- in 1000ml
In 250ml =106/1000 x250 =26.5g
Therefore to make up the 250ml of .25M Na2CO3^2- add 26.5g Na2CO3^2- to 250 ml
leah3000 said:
Mols= 0.25x1000/250
=1mol
Not sure what you are doing here, 250 mL of 0.25 M solution doesn't contain 1 mole of substance.
By definition molar concentration is
C = \frac n V
solve for n to find the formula that let's you calculate number of moles of substance in given amount of solution of a given concentration.
