Calculating Earth's Temperature Change from Increased Solar Constant
  • Thread starter Thread starter TheMathNoob
    Model
8 replies · 3K views · last reply
TheMathNoob
Over the last ~100 years, the average solar constant has increased by ~ 0.1 W/m2.
How much would the Earth’s temperature change simply due to this increase in the solar constant?
[L * (1 – a)] / [4 * e * sigma]) 1/4 = Tground
L is the incoming solar radiation in the earth
a is the albedo
e is the emissitivity
sigma is the Boltzmann constant[
We showed that a = 0.3, e = 0.6, L= 1350 W/m2, gives us a realistic surface temperature.
I attempted this by increasing the incoming radiation of the sun by 0.1, so it would be 1350.1, but I think this is wrong because the solar constant is like the constant for emissitivity, so I would think that in some way, I have to calculate the new L which is the incoming radiation of the sun.
([L * (1 – a)] / [4 * e * sigma]) 1/4 = Tground
a is the albedo
You would be well advised to edit that post to put the Font size back to normal (Size 4) and remove the Bold-ing.
Done, now help me please!
Is that 1/4 supposed to be an exponent for part, or all, of that expression?
Also: L is the solar constant.
Yes
Not sure what you mean. It is not some physical constant. Indeed, it probably should not be called a constant.
a is the albedo
Is this L the "old" or "new" value? In other words is it calculated for the present or 100 years ago? If present subtract the given change, 0.1. Calculate Tground with both old and new values to see how much it has changed.
3. The Attempt at a Solution
In this case, L is old and then we have to calculate the new T by increasing L I think by 0.1
No.
Just increase the old L value by 0.1 W/m2 .
